Question about Brother DCP 130C All-In-One InkJet Printer
Brother dcp130c paper tray wont slide out, moves out 5=10mm only then stops as if it is jammame dagainst a stop at the right side rear of the machine.
  • indigoflower Jan 14, 2009
    i have the same problem and no instructions of how to pull tray!!!
  • tawney4 Feb 10, 2009
    same problem here.
My sistern gave me a brother printer DCP-130C I do not know how to open the paper tray looked everywhere i dont have a information booklet please help!!!!
I have a link to a website which will help you with the paper tray problem.
It is
This link is to a DCP-130C User's Guide. If any other problems arise, look through the guide.
Look on page 14 ( Loading Paper, Envelopes and Other Media ) concerning the paper tray.
If you don't have an installation disc, look at the site below for help.
Feb 10, 2011 | Brother Office Equipment & Supplies
When you send something to print it stops, the attention light blinks red and once you click on the green CHECK button it prints again. Why does it act like its jamming?
  1. Slide the paper-width guide to its widest position, and then pull out the paper tray extender. Figure 2: Move the paper guidesc00648140.gif
  2. Insert plain white paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops. Figure 3: Insert paper into the productc00636180.gif
    CAUTION: Make sure the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  3. Slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Adjust the paper guidesc00636178.gif
    NOTE: Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Nov 09, 2010 | HP LaserJet P3005n Printer
I am having a problem with the paper tray for Brother MFC 8860 dn printer - The paper tray clicks when it is printing a page and then says there is no paper in the paper tray or that a page is jammed -...
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Oct 13, 2010 | Brother MFC-8860DN Printer
Paper tray problem - full of paper but can't pull up paper and display says tray empty also loud clicking noise coming from paper tray
hopefully we can stop problem before it gets worse, take paper tray all the way out of machine, look at back of tray where paper stop is, move to LTR make sure arrow is pointing directly to it, not before od after, then lock it in, the pictograhm has a pad lock symbol to show locked and unlocked. if the blue tape is still in paper tray, remove it. hopefully no damage done to pick up assembly, or gears on paper tray
Sep 25, 2010 | Brother MFC-8460N All-In-One Printer
Says unable to print 4f, see troubleshooting and routine maintenance. please help.
This is a print head failure of some type. Turn off the printer, disconnect the power cord and lift up the scanner unit. Check for any paper or foreign object. See if you can slide the printhead and check under it. If the printhead will not move easily, do not force it. If the printhead is all the way to the right, you will not be able to move it. Use a flashlight to check for any foreign objects or paper scraps soaked with ink. Remove any foreign stuff that you find.
Sep 15, 2010 | Brother MFC-5460CN All-In-One InkJet...
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Brother hl 4040cn will not load paper from tray loud clicking noise coming from paper tray on dislplay it says no paper
Remove main tray. Check adjustable paper back stop. If the backstop is set so that the paper sit too tightly in the will prevent the spring loaded front portion of the tray to lift up allow paper to contact the pickup roller. The clicking sound you hear is the paper lift mechanism trying to push up the paper. Arrange both backstop and sidestops to allow some movement of paper in tray.
Apr 13, 2009 | Brother HL4040CN Laser Printer
No Paper Message- when the tray if full
When removing the tray - turn off printer -
insert try with paper - turn on printer -
you should notice the blue paper meter moving. fixed
Oct 20, 2008 | Brother MFC-8460N All-In-One Printer
Brother DCP 130C All-In-One InkJet Printer Logo
488 people viewed this question
James Cagle
James Cagle
Jim Keysor
