Euro Tech Washing Machine I the craked around the sides , can this be replaced? How much and who can I contact inToronto?
I contact the Comapnay directly!
Posted on Jan 03, 2009
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
https://www.youtube.com/watch?v=QndkRbDfM2w
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ...
Amazon.com: Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
Why the washing machine cloud not rinse ? at the rinse step, I heard like motor jam sound ( shuttering sound) from the back/bottom, any idea ?
first I'd check filters, there should be one at front bottom. but it sounds like drain pump is gone. they cost around 40-50 euro.
Nov 05, 2014 | Washing Machines
Lower feed dogs on a Euro Pro
look to see if there is a little slid switch some where around the side or the back off the machine
Oct 06, 2014 | Euro-Pro Sewing Machines
My machine will not connect top and bottom stitches
Your machine's timing is out. I know of no one that services these, but you might call around your area for a sewing machine tech... who knows you might get lucky.
Linda: I don't want to seem mean or unpleasant, but I would seriously think about scrapping this machine and getting one that you can get parts for and help locally.
Feb 25, 2013 | Euro-Pro Shark 80 - 7133
My washer fills up with water and nothing else,the motor still runs but it doesnt spin wash nothing
As you said in the question you are using Euro Tech EWF 150 you are washing machine have problem with the belt.Belt will be damaged you just need to contact the nearest washing machine center so that you are washing machine will be just fine.There is no big problem it's just a small problem.If you no how to fix that belt means you can fix the problem.Thanks for your question.
Jun 19, 2011 | EuroTech EWF150 Front Load Washer
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Derek
Jan 17, 2011 | Euro-Pro 473
The needle will not go down all the way, so it dosent sew on my euro pro, 7133 sewing machina
Check the manual to be sure the needle is installed correctly, this is usually with the flat side of the shank facing the back of the sewing machine.
Make sure the needle is not bent.
Also, there may be thread tangled in the bobbin area. Open the needle plate and bobbin; clean away any lint or thread that has accumulated there.
If this does not resolve the issue, the machine will need to be serviced/repaired by a sewing machine tech.
Mar 18, 2010 | Euro-Pro Shark 80 - 7133
Leaking radiater
the radaitor is craked it needs to be replaced looking to help Shaun
Nov 15, 2008 | 1993 Saturn SL1
Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Generic problem for all Vacuums
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
