Question about OTC LaserMatrix 2400 Printer
Will not scan to my pc
My Lexmart 2400 will not scan to my pc-- all cables are connected right
  • 106 Answers
Recoonect the scanner and see whether your PC detects the scanner or not there might be a faulty USB cable, try reinstalling the software.(If you are using windows XP, go to control pannel>Camera & scanner and check whether your 2400 is there in the list or not)Cancel if there is any pending jobs. Restsrt the PC and try again. It should work otherwise the scanner might need a servicing.
Posted on May 01, 2007
SOURCE:
Casio te 2400
On casio if you have the right cable it is just a pplug-n-play. once you plug in your cable on your screen the word comms apeears then press enter
Feb 19, 2014 | Retail Supplies
Dell Dimension 2400 can't get ip address
Cable right connected? Have you a router or a serve who give an IP address, or is your ISP who give the IP. Try to reboot the DHCP server, then start your computer and try again.
Jul 26, 2012 | Dell Dimension 2400 PC Desktop
I cannot scan with the hp scanjet 2400
just reinstall the scanner driver and check the usb cable is connected properly. , right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | HP ScanJet 2400 Flatbed Scanner
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
How do I get my TV to display my Dell Dimension 2400? I have the cables for the connection and I have connected other computers to to TV with no problems-- it seems this is more of a software/display...
Try this: right click on the desktop (wall paper picture) and select "Properties" (up to XP) or "Graphics Options" (Vista). You should be able to select you TV as a second display. The TV option may only show if it is connected.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Where is the printer hookup on this computer?
if it is a 25 pin parallel cable there should be only one place to plug it, if it is USB you can put it in ANY USB socket
Oct 04, 2008 | Dell Dimension 2400 PC Desktop
I cannot load the software drivers to my Lexmart X6570 printer. It will make a straight copy but will not print from the computer or scan. I have tried the CD that came with the printer and tried to...
hi is the pc your on xp or vista ?
some printers are not compatible on vista if this is what your using there is however a fix for this go on the net and down load a program called driver genius 2007 pro this will find any driver problems on your pc sys and down load the drivers to fix any problems on you pc complet .
hope this helps ok thanks
May 22, 2008 | Lexmark Office Equipment & Supplies
Lexmart x4580 all in one printer
Hi I have a Lexmark x4580 all in one WI FI dos not connect to my netgear it finds it and I put in all the right passwords just will not connect
Dec 04, 2007 | Lexmark X8350 All-In-One InkJet Printer
Won't work
When well Lexmart have the proper driver for me to install? Its been almost two months since I first contacted them by phone,I'm asking for someone to call me in the afternoon to explain when I can have my printer working, I need it bad! Phone#501-812-0691 Thank You Keeling
Mar 11, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
OTC LaserMatrix 2400 Printer Logo
Top OTC Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you an OTC Office Equipment and Supply Expert? Answer questions, earn points and help others
