Question about Northstar Garden
Unable to start gas engine on a NorthStar pressure washer
I have a NorthStar pressure washer (model # 1578922A), with a Tecumseh OHH55 gas engine and an Annovi Reverberi XTV pump (2030 PSI, 3 gpm, 3400 RPM, 4 HP).  I have been using it for several years without a problem.   However, now I am unable to start the engine.  The last time I ran the pressure washer, I noticed that the washer would sometimes "drag", acting as though it wasn't getting enough water through the pump -- though I checked the hoses and they were fine, without any kinks or leaks.
Here's what I have done: (1) replaced gas in tank with new gas (the gas was fairly old). (2) replaced air filter (it was pretty dirty). (3) replaced spark plug (I am getting spark). (4) cleaned out water inlet screen (it was a little dirty, but not too bad). (5) removed unloader valve and cleaned in soapy, warm water. After doing this, I am still not able to get the engine to start.  So I tried several other things: (6) instead of using the gas/carburetor priming bulb, I just shot some starting fluid (for drying out spark plug wires in car engines) directly into the carburetor.  The engine did startup briefly, but it never was able to go more than a few seconds before quitting. (7) I noticed that the pressure washer's starter pull-rope-coil would feel some resistance after a few tries on the pull-rope.  So I engaged the trigger on the gun while trying to start the engine.  Perhaps there is a issue with the pump itself?   Nevertheless, I was not able to get the engine to start, even though the resistance was now gone.  I probably should never have to engage the trigger on the gun while trying to start the engine since hopefully the unloader valve should take care of any problems.
I am not sure what to try next.  Are there any suggestions of what might be wrong, what can be done next to fix this?
  • cmorledge Jan 10, 2009
    I actually found two problems with the pressure washer engine:
    (1) Yes, the carburetor was pretty dirty.  It took a few cleanings with some Gumout Air Intake and Throttle Body Cleaner and some canned air to clear out the gunk, but that took care of most of the problem.  Fortunately, the side-draft float bowl design on these Tecumseh carbs are pretty easy to work on without having to completely tear it apart.
    (2) Also, there was a leak in the breather tube.  Basically, the rubber tubing had split in half, so I replaced that as well.
    Now everything is working perfectly.  Thanks for the help!
  • 2,692 Answers
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Posted on Dec 30, 2008
  • Thomas F. Schneider Jan 11, 2009
    YOu are welcome Thanks for the positive  vote.
I have a Tecumseh 5.5 Enduro Power Washer and need a replacement carb for it.
If the carb is still intact, you may just want to rebuild it. Parts are easy to find and inexpensive.
Jul 11, 2015 | Tecumseh Garden
Tecumseh model#OHH60-7193d. Need a carburator
These are readily available on Ebay for less than $20.00.
TECUMSEH CARBURETOR 640025A 640014 640004 640025B 640025C OHH55 OHH60 GCA68
May 29, 2015 | Tecumseh Garden
I have a Tecumseh OHH55 on a wood chipper. I replaced plug, oil, new fuel and cleaned up. I cannot get it to start. Carb was also cleaned. Any suggestions before I take to a repair shop.
Is fuel getting to the carb? Check the fuel line it may be plugged. The rubber deteriorates after many years and plugs up the line and or jets. Its always best to replace the fuel hose when you rebuild the carb. Have you checked for a spark at the plug?
Aug 09, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Northstar Pressure washer starts and runs but dies when throttle is opened up
is this a v-twin engine or has the unit been stored for quite some time with fuel in carburetor.inspect fuel jet and tube for restriction.
Jul 28, 2013 | Garden
Tecumseh ohh55 smoking/burning oil
one of many suppliers on the web- lol
Jan 07, 2012 | Tecumseh Garden
Looking for an electric starter for Northstar Model 157892A
Is this the engine model number or the machine model number? Is the motor already set-up with an electric start or is it something you are looking to add?
Oct 30, 2010 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
Replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
Jun 06, 2009 | Mtd Garden
Garden Logo
605 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
