Question about RIM BlackBerry 7250
Initial setup with SIM card
Where does the SIM card go on this model? bought one on internet and can't figure out how to activate.
  • 30 Answers
This Blackberry uses the CDMA band, not GSM. It does not use a SIM card. You need to check with your wireless service provider to see if they offer a CDMA network.
Posted on Dec 30, 2008
My device requires sim card with gprs and mms. what does this mean?
Smart MMS and mobile Internet / APN settings. Smart's MMS and mobile Internet (GPRS, 3G, etc.) settings are automatically pushed to your device upon activation of your SIM. Your phone will receive the configuration settings along with text messages containing instructions to install / activate.
Smart MMS and mobile Internet / APN settings - Smartopedia - Help ...
https://help.smart.com.ph/article/prepaid-smart-mms-and-mobile-internet-apn-settings
Settings - Vodafone
https://vodafone.is/english/settings/
This applies only to devices using a Vodafone Iceland SIM (does not apply to users roaming into our network). Here is an overview of the settings that work on the Vodafone Iceland network. APN: vmc.gprs.is (Mobile Internet SIM cards) or gprs.is (SIM cards with voice service) If you are using a dedicated Mobile Internet ...
Activate My GPRS/MMS - Dodo Support
https://www.dodo.com/support/billing-and-accounts/mobiles/activate-my-gprsmms/ If your sim card is active, GPRS is also active. If GPRS is not working, please check if you have the correct GPRS settings. If your settings are correct and the sim card is active but GPRS is not working, please call our call centre to investigate the issue. The table below contains the Dodo GPRS and MMS settings ...
sim card with gprs and mms Google Search
Dec 11, 2017 | Cell Phones
I lost my cell phone yesterday and happened to still have my old SIM Card with the packaging and everything that I bought a year ago. I still have all the info on the larger card! info in details vvv
Soounds just fine but you should tell all thios to T-mobile. Contact them just ANYWHERE. They have store. Or call them throum Attention to Customer 1-877-296-1018.
May 04, 2015 | T-Mobile USA (Tmobile T Mobile) SIM Card...
My Samsung Galaxy S2 GT-I9000 doesn't read my SIM Card
Can't figure out exactly what the problem is. Try with the following methods.
1) The SIM card might be damaged. To check this, Try inserting the SIM card into any other active network free phone. If it doesn't work then sure the SIM card is damaged. If it works fine then the SIM card is in good condition.
2) The SIM port on your phone might be damaged. Try inserting any other active SIM card to it. If it doesn't work, then sure the SIM port is damaged. If it work fine, Then the SIM port is in good condition.
3) The phone might be network locked. If the phone doesn't allow any network SIM cards to work with it except any one specific SIM card, Then it is sure network locked. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy S2 from ProUnlocking.Com at affordable cost with easy unlocking guide. Good luck.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
My Sim Card won't read in my LG Gm310 phone
Perhaps the sim card was not initialized. Initialization allows you to communicate.
Feb 11, 2018 | LG Cell Phones
I bought a lg xenon and it keeps saying sim card initializing or sim card not ready! Why is it doing that?
Either your SIM or your SIM reader have probably gone bad try getting another SIM first tho and if that doesnt work you may need to have the phone repaired
Feb 28, 2011 | LG Xenon GR500 Cell Phone
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Bought a LG Shine from canada and put in my at&t sim card, how do I set up my yahoo account?
First you should activate your sim either by calling customer care or following the instruction on sim manual,
your phone has an Email setup wizard,open,follow the steps given,choose yahoo n brows
Jul 02, 2009 | LG Shine KE970 Cellular Phone
Problem with Motorola V3 Razr
Go to your settings, choose Initial Setup, choose Language and hope English is one of the options you can choose. My Razr is old so hopefully the options are still the same.
Aug 09, 2008 | Motorola Mobility RAZR V3
Anylink N99i dual sim mobile phone
setup > call setup > line switching
i guess u can use just one line at a time
u can't put them both on at the same time
let me know what happens.
Feb 15, 2008 | Cell Phones
RIM BlackBerry 7250 Logo
688 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
