I put to much oil in trans
If it's an auto box, it cannot be drained without removing the pan from the bottom of the box or, much simpler, a clean polythene type tube, with a syringe, inserted into the gearbox filler tube, and draw some of the excess fluid out. If a manual box, there will be a level plug on the side of the box
SOURCE: My 2004 Kia Sedona make a grinding noise when I
Something in the transmission is probably not right. Sounds like a small gear has stripped and is trying to go ahead and go into gear, or the gear is chipped and is making that sound because it is chipped and not going into the other gear as smoothly as it should. I would take it to a transmission shop where ever you live and get it checked out. That's one thing about automatic transmissions, they have to be worked on by a transmission specialist nowadays. Try that and let me know what you found out.
SOURCE: Changing transmission fluid for 06 Kia Sedona
Transmissions these days need very little maintenance, our fluids are advanced formulas that hold up for an average of 100,000 miles, most vehicle manufactures recommend no maintenance for automatic transaxles these days.As for a transmission flush I don't recommend this because it's an expense that is not needed and possibly could loosen some contaminants setting them loose to possibly clog some of the very small passages in the transaxle requiring full transaxle service,which could include removal,dissassembly,etc of your trans.Now draining and replacing fluid is OK if that makes you feel a peace of mind but normally not needed,if you decide to do that,as far as quantity just note approx. how much fluid is drained and purchase similar amount in quarts and then refill (DO NOT OVERFILL)
start engine, let it warm up to operating temp,then check the transmission dipstick for the correct level,remember the vehicle needs to be on a level surface,hot idiling in park when you check the fluid level. Good luck !
SOURCE: gearbox oil
how do you top up the gearbox oil on a kia sedona 2.9diesel on a 03 plate and i have friction noises when driving changing gears.
SOURCE: How to change the oil on a 2005 Kia Sedona
The oil filter is towards the front of the car, underneath on the passenger side, at the corner of the engine cradle. Loosen the drain plug and drain the oil. Make sure the old oil filter gasket came off with the oil filter. Reinstall the new oil filter. Reinstall the drain plug and fill with 5 quarts of 10w/30 motor oil.
SOURCE: kia sedona automatic transmission gearbox
To fill the transmission fluid, you need a funnel that fits into the dipstick tube, add fluid there. If the fluid is black and smells burnt, that's bad. I would have the fluid changed. These transmissions don't have a filter, probally a bad idea.
