Question about Bose 3·2·1 II System
Need to perform factory reset
By accident, my series II system is in PAL mode (instead of NTSC). Because of this, I cannot access the onscreen setup menu to change back because the TV reports an unrecognized format. Is there any way to reset the Bose system without utilizing the onscreen menu, i.e. pressing a series of buttons on the remote/device to force it to factory spec?
  • 8,596 Answers
When I worked for Philips, I solved one of these. First, try unplugging the unit from the wall outlet for one full minute and see if that alone will reset the unit/restore it to defaults. If not, make sure you have a yellow video connector running from the Bose to your TV rather than another type of video cable - change the tv to the appropriate source channel - now see if the menu will appear. If not, you will have to fly blind (don't mess up): Press the System button, then the right arrow by the Enter key twice, then the down arrow by the Enter key five times, then press Enter. Defaults (including NTSC) will now be restored.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
  • rajn505 Sep 26, 2010
    Easy Solution:
    Swithc off Boss System, Press and Hold Enter key in the System and press and release store. A selection will appear each time you press store button. When it comes to video use volume button to point to NTSC and click Store.
    Hope this will slove the issue.
DVR ED6008ME WON'T START AFTER FIRMWARE UPDATE. IT HAS A VIDEO SYSTEM: NTSC/PAL
Incorrect firmware if possible do a firmware factory reset if not take to qualified repairer for further assistance.
Jan 13, 2013 | Video Game Consoles & Games
Colors are off
Hi!
maybe your PAL NTSC SYSTEM mode is in accidentally switch to PAL or NTSC try to re switch the PAL NTSC SYSTEM mode.
Nov 02, 2007 | Mitsubishi WD-52725 52". Rear Projection...
How to convert my Philips DVP5990 to play PAL?
Press SETUP
Use the arrows to highlight Video Setup Page
Select TV Type - change it to PAL
There isn't a way to view PAL and NTSC at the same time with this player, but you can always go to the video setup page and switch between the two. Restoring the player back to its factory defaults will automatically switch it back to NTSC.
-Tha Mp3 Doctor
Feb 13, 2009 | Philips Televison & Video
I bought a dvd player cobusa model dvd-224. the box stated that it can play Pal and NTSC dvd discs.How does one setup for pal region 5 disc? When I setup for pal I get a rolling black and white picture...
Check to be sure that the setup is correct. The picture you are describing is what happens when you play PAL into an NTSC unit. I don't think you are in PAL mode.
Dan
Jun 27, 2008 | Televison & Video
Switching form PAL to NTSC
did you tried to switch back to factory settings? thanks
Apr 11, 2008 | Bose Lifestyle 38 System
Black and white picture i did switch my setting to the pal by accident
set the palsecam or ntsc mode! or you have defective board video drive!
Oct 02, 2007 | TruTech TT1620 DVD Recorder
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Bose 3·2·1 II System Logo
890 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
