Question about Denon AVR-1601 Receiver
Avr receiver i have an denon avr 1601 receiver.it powers on and imediately powers of what can be the solution.thanks very much ps:ineed aowners manual for the receiver were can i find it?
  • 1 more comment
  • oldskoolpro1 Nov 22, 2007
    yep, same prob
  • Haapy Yogy Jan 02, 2008
    i have an denon avr 1601 receiver.it powers on and imediately powers off
    >>> I found out problem and fix mine >>>> at the power supply area they have 4 resistors 1.00 Ohm 1/4 watt .....Location r141 r142 r148 and r149 (R148 and R149) burn out >>>> good luck to all of you
  • chukg9 Jan 05, 2008
    i turn ot on and the n when the display changes to receiver the unit turns off
I had same problem with my denon avr 1601.I have fixed it by myself by favour of Haapy Yogy. Thank you.
Posted on Feb 19, 2008
  • 76 Answers
More than likely audio o/p problem.could be speaker problem,dissconnect speakers and try to power on if still no go it is job for technician.If it works one of your speakers has a short on it,good luck
Posted on May 15, 2007
  • 125 Answers
Check for the crack solder and resold or try replace the regulator
Posted on Jan 01, 2011
Hey does anyone have a diagram on the board 141 and 142 are? im having trouble finding them.. i found 148 though :)
Posted on Sep 26, 2009
  • menasan Oct 05, 2009
    i replaced the resistors suggestions by happy yoga with 1 watt flameproof .22 ohms 2% resistors.. didnt fix the problem :(
Pre out for Sub woofer on AVR 1601 not working
Is this a new problem, as in it worked before? If it's a new hookup, it's possible the sub you have isn't powered. In which case, it won't work. PRE out is 'preamp' for powered subs.
Dec 27, 2013 | Denon AVR-1601 Receiver
Service manual
http://www.smpcshop.com/Denon-AVR-1601-AVR-681-Service-Manual.html
Sep 11, 2013 | Denon AVR-1601 Receiver
What is the button combination to reset the Denon AVR-1601 to factory presets?
switch off, then hold A and B speakers, then switch on and hold about 3 seconds. This is reset to factory defaults.
Jul 22, 2011 | Denon AVR-1601 Receiver
Dennon AVR-1601, Installation, Connections & Operating
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Jan 06, 2009 | Denon AVR-1601 Receiver
Dennon AVR-1601, Installation, Connections User guide
here are two relevant links for hookup and such
http://audio.manualsonline.com/manuals/mfg/denon/denon_avr_avr1601.html
https://usa.denon.com/us/downloads/manuals-and-downloads
Oct 14, 2017 | Denon AVR-1601 Receiver
Manul denon avr-1601 en castellano
Espagnol as well ...I think
Dec 12, 2008 | Denon AVR-1601 Receiver
Denon avr 1601 amp
Yes, although there may be an efficiency factor involved...accordianman
May 01, 2008 | Denon AVR-1601 Receiver
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Nov 21, 2007 | Denon AVR-1601 Receiver
Denon AVR-1601 Receiver Logo
750 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
