Question about Sony PlayStation 2 (PS2) Console
Loud humming sound coming from TV speakers
This problem has happened with the same console but with different TV's. To get it to stop I turn off the TV and Playstation. Then restart each. Sometimes the same loud humming happens again from the TV speakers
  • 709 Answers
I believe this is a dirt and contamination issue within the PS2. You need to open the case and thrououghly clean it out. This means thoroughly, Motherboard, and all. You will need a can of circuit board cleaner.
Posted on Dec 30, 2008
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Loud humming noise from new hdtv
hello, the speakers are fualty or have a shorted connection if they came with the tv contac your seller and arrange for a replacement imediately dont wait. since they are giving you feedback dont use them they may cuase other fualts in your tv, any component thats cuases hum or noise when pluged into the tv should not be used at all.
one important thing is to have a grounded plug this also may cuase fualts down the line,
if posible get a power line conditioner or ups (uniteruptable power supply)
flat panels are very over protective you dont want the tv to start blinking. since flat panels have built in protection circuts any slight short or fualt may cuase the wide screen to go into circut shutdown mode and this will cost you more if the speakers create a short in your audio circut it may damage your widescreen internal boards and cuase a system shutdown circut (red light flashing no picture)
contac your sellers site let them know your speaker are cuasing a loud hum
and that you will need the speakers replaced these are definitely fualty
if you dont have any coverage or you got the set as is then dont take any chances use other speakers.
if you are electronically inclined you can open these up and find out whats wrong with them internaly it may be a loose connection, since opening up the equipment may void your warantee contac the store first see what they say..
good luck happy holidays
Dec 10, 2008 | Hannspree Televison & Video
Humming
More often than not, the humming sound on any electronic device is brought about by the AC side of the power supply not only of the device itself but also all other equipment it is attached to. In your particular case, it maybe introduced into the system from:
  • (coaxial) cable TV leadin;
  • connections of DVD, VCR, game consoles and others;
  • electrical noise from lamp dimmers, lights with electronic ballasts, wireless phones.
It is interesting to note, that the noise could be from other appliances plug in the same circuit as the TV, you of course could try plugging it into another outlet or branch. In some instances, you could even try filtered regulators similar to those used by desktop computers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 13, 2008 | Proscan 32LA30Q Television
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
Sound problems
The problem is the sound card on the t.v
Oct 14, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
