I have a panasonic pt-56tw53 projection tv and th green tint is out of adjustment it is rounded on the top and bottom
  • 55 Answers
When I had the same problem with my Phillips big screen it was the bulbs. Usually around $100 per bulb and like 3 bulbs in there.
Posted on Dec 30, 2008
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My tv has a arching green tint towards the bottom of the screen that also gives off a double image. I have a Panasonic hdtv 47 in screen model no: PT-47wx54j
Convergence problems. If they can't be fixed from the setting on the menu then the convergence board's IC's are faulty and must be replaced. This is a job for someone who has some electronics experience.
Aug 09, 2010 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic Model #PT51HZ41E Blue is not converging, red and green perfect. Blue lines move but will not converge have replace STK392-110 checked all resistors what else could the problem be
On my Panasonic PT-56TW53, the down left quarter of the screen has a big colour distorsion. Convergence can adjust blue and red, but green is not able to show a straight line. Is tis a mechanical adjstment? Help would be great.
Feb 11, 2010 | Televison & Video
I have a panasonic rear projection lcd, it has a yellow tint around center of screen. Help
My PT-43LC14 has a yellow tint on 3/4 of the bottom to top. the top 1/4 seems normal. I removed the bulb assembly and it looks OK. Any ideas. Is there anything I can doe myself. and if so what is the p/n I can buy?
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
