Question about HP PSC 2210 All-In-One InkJet Printer
Refill cartridge I refilled my ink cartridge and tried to go through the alignment process. Part way through it would cancel the alignment and it would say to press enter to align. I would readjust the cartridge, but it would do the same thing. I have put several new ones in and it would adjust with no problems. Thank you for any advice.
  • 106 Answers
Try cleaning the the contacts of the cartrides and the holder it should solve the problem if it doesnot then probably the cartridges got damaged while refilling. Just ignore you can still carry on printing jobs.
Posted on May 01, 2007
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
I refill my cartridge hp d1660,how to reset cartridge ink level?
Hum.... D1660 is not easy to reset the ink level.
Whenever you print.... Press cancel buttom first and Press Power button(with holding cancel button) and let go at the same time... should hold about 3 sec.
At least you can get the print out... Little pain in the ****....
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 04, 2011 | HP D1660 InkJet Printer
Printhead problem
Do a test print & alignment followed by another test print. Refill or replace ink cartridges as necessary. eBay is a Good source of ink refill kits. Just be sure that your printer is named in the ink refill ad.
Apr 13, 2011 | HP Photosmart C6180 All-In-One InkJet...
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Clive
Clive
