No lights on, no blinking lights when power button pressed. Nothing.
I am sure the tv is shot from the surge but you can check a few things. I would take the tv apart and test the power supply first. Look for obvious burn damage throughout the boards. If there is a blackened one (prob video board) then you can try to replace that. Don't worry about taking this apart and breaking it further. In this case it can only get better for you.
Thank Jerry, I think I will give it a try and look for obvious damage with the fuse and capacitors.
Hi Jerry, thanks for responding. I've looked for obvious damage (nothing). Shouldn't the fuse by the power supply be blown? I also have a Sony Home theater system that was blown as well as and LG Home Theater System. I need some help Bro. all my entertainment was blown at once. I'm a California Boy, never had this happen, is there anything you can suggest? Thanks I know time is valuable yours is appreciated...TLG...
Sorry...haven't been on in awhile. Fuse is not always by the power supply. It is put wherever it can fit. Keep looking. I would also suggest a real surge suppressor which I can suggest if you are interested.
HI KDL 46EX400 SONY LCD TV'S TURN ON LIGHT NOT ON i CHECKED REMOTE CONTROLL AND POWER SWITCH NO RESULT. WHAT IS THE SOLUATION. jkp
SOURCE: My Sony Bravia LCD Model-KVL37S400A
Hi
You may have a power supply problem with the unit. Have the unit checked for correct power voltage ratings on the PS. Or just replace the power supply
Testimonial: "Hi, Thanks for the response. Could you please tell me what would be the cost if i replace the Power Supply Unit."
SOURCE: Lightning strike to a Sony Bravia KDL-37m4000
Check if all the PCB board intack.Might worth repairing.
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
SOURCE: Sony Bravia EX400 HDTV LCD, after lightning
hello marksrapolai
that problem releted with BA board so replace it then ok
if you know more please call me on +91 9274498896 or mail me
to [email protected]
SOURCE: My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
