Question about Kitchen Ranges
Whirlpool stove clock malfunction..
I have an electric Whirlpool stove, about 10 years old. Recently, after the oven has been on for about one hour, the clock starts to blink, the time changes to 55:00, it starts to beep and then the numbers disappear and it says 'door'. Then it shuts down.
A friend told me to unplug it and then plug it back in, this way it will reset the clock.
I have done that, and it resets it, however, the sae thing happens again when the oven is on for a while.
I have checked the stove fuses, they look fine - including the one for the oven.
Any suggestions would be greatly appreciated.
Thank you
Zena Pendlebury
  • 115 Answers
You have a bad electronic oven control or in other words bad clock
Posted on Dec 30, 2008
My oven and stove top isn't working at all. If I turn a burner on, the clock and oven light up, but the burner doesn't get hot and either does the oven. It's only 8 years old and isn't used often.
I was having this problem and it was because I had tripped the breaker. Reset the breaker (box Inside your home) and try that, However, there is probably an underlying electrical problem that should be fixed asap. I live in an older remodeled mobile home that isn't equipped to handle a lot of appliances going at the same time. Try to make sure you aren't pulling so much power when you use the stove, ex: TV, microwave, oven, stove, all running at the same time.
Nov 19, 2010 | Whirlpool Accubake RF362LXTT Electric...
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Jul 24, 2007 | Whirlpool RF3020 Electric Kitchen Range
Kitchen Ranges Logo
335 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
