Question about Olympus VN-4100PC Digital Voice Recorder
Download to Windows XP Media Center Edition 64 bit
For some reason, I can open the digital wave player, but it will not pull files from the digital recorder (which acknowledges being attached to "pc"). I didn't have any problems on my 32 bit windows XP computer, but it crashed. I have the most recent version of the player (2.1.4). What to do?
  • 2 more comments
  • Anonymous Feb 18, 2009
    I GOT the same problem but with my 32 bit windows
  • Anonymous Mar 28, 2009
    Same problem
  • Mike in Clev Apr 01, 2009
    I have the same problem. I have two digital voice recorders - liked my first one, a model VN-240PC so much I bought one for my wife. I borrow it sometimes. Can't download the files from it.
    The Digital Wave Player program opens, it seems to recognize that there are files on the digital voice recorder, it tries to transfer them, then "poof," it shows that it's done but the files are not transferred and it all goes back to how it was before I tried to transfer.
  • Anonymous Apr 21, 2009
    el mismo problema
2 Suggested Answers
  • 1218 Answers
SOURCE: I have an Olympus VN-2100PC Handheld Digital
Yes you got a new computer but unfortunately the vn-2100PC is not compatible with 64 bit OS's neither XP 64bit or Vista 64 bit...therefore it will also not work with 7 64bit.
Feel free to verify by checking at www.olympusamerica.com
Posted on Nov 09, 2010
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Windows xp media center edition 64 bit
It is only compatible with 32-bit Windows XP
From their site:
  • Windows XP with Service Pack 3 or higher (32-bit only)
Sep 17, 2013 | Trend Micro Computers & Internet
I have no sound driver
Please use the below link
For all drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCCR
select the operating system then
select DRIVERS in select download type.
then download the sound drivers. and install.
For Audio drivers: Click on download
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19472&lang=eng
AUD_Vista_Win7_6.0.1.6201_PV.exe for vista or win7 AUD_XP_5.10.0.6201_PV.exe for xp. If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 02, 2011 | Intel D945GCCR Motherboard
WE WANT WINDOWS 7 EPSON PRINTER R230X
Epson Stylus Photo R230 6 Colour Inkjet Printer files Driver Printer Driver 6.52E
Windows 2000, Windows 7, Window Vista, Windows XP Posted: 24/11/2009
Click here Utilities Epson Easy Photo Print 2.23.01
Windows 2000, Windows 7, Windows 7 64-bit Edition, Window Vista, Windows Vista 64-bit Edition, Windows XP, Windows XP 64-bit Edition EPP_22301_EHKT.exe
Posted: 19/1/2011 Download
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
I have an Olympus VN-2100PC Handheld Digital Voice Recorder. I have the olympus digital wave player cd that came with it. I recently purchased a new computer with windows 7 -64 bit. How can I get the...
Oct 30, 2010 | Olympus VN-2100PC Digital Voice Recorder
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
Windows XP Home Edition
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
Windows XP Professional
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Jun 03, 2010 | Microsoft Windows XP Professional for PC
I need Digital Wave Player soft to work with VN-480PC
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
I can tell my player plays but I have no sound. I have deleted 90% of the files, have already reset and reformat the player but with no result. Still no sound.
Hello.
Welcome To Fixya.
To solve thhis problem you need to upgrade the Firmware of your Mp3 Player.
Please follow these steps:
Once the download of "ContentTransferInstaller-v11.exe" is completed (Please download the file from the Link Below),please follow the steps below to install the Content Transfer Version1.1 on your computer.
  1. Quit all software.
  2. Confirm the PC is connected to the Internet."ContentTransferInstaller-v11.exe" will download the files necessaryfor your PC.
  3. Click Start on the task tray and click Run... * Then the dialog box Run
  4. Input C:CT1.1_dlContentTransferInstaller-v11.exe and click OK.
  5. The Content Transfer Version 1.1 installer window will appear on screen.
  6. Follow the on screen instruction to complete installation.
  7. Click Finish after the installation.
  8. Check whether the installation is completed successfully.
Important:
Windows 98SE, Windows ME, Windows 2000 Professional, Windows XP MediaCenter Edition, Windows XP Media Center Edition 2004, Windows XP MediaCenter Edition 2005 and Windows XP 64 bit version OS are not supported.
Downloads:
Additional Help:
Manual Guide for NWZ-S616F.
Thank You for Using Fixya
Good Luck
Nov 06, 2009 | Sony Walkman NWZ-S616F MP3 Player
Corrupt files in MCE 2005 XP home
try uninstaling your windows media player then reinstaling it
it seems thers error in your media player files
hears a link 4 re download
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
hope i was helpfull
goodluck
Mar 20, 2009 | Microsoft Windows XP Media Center Edition...
Transfer recordings on my Digital wave player on my computer to a CD
on xp, you will need to convert the recordings into 16 bit wave file through the sound recorder on your computer... you may need to call olympus for more details
Sep 23, 2008 | Olympus VN-2100PC Digital Voice Recorder
Olympus VN-4100PC  Digital Voice Recorder Logo
539 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
