Question about Mitsubishi WS-55807 TV
Picture bows in on sides,top and bottom.Sometimes when you bang on right side picture straightens out.most of the time when tv warms up problem goes away.
  • hawkis Dec 30, 2008
    I have the same issues with the bowing. Sometimes it's okay but most of the time, it bows. It's acutally better with a digital DVR (DTV/Tivo) then with the DTV HD box.
  • 934 Answers
It's ring-cracked solder joints on the foil side of the board, most likely in the convergence circuit...
Bill
Posted on Jan 04, 2009
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Problem with tv picture
Smack it firmley on the side and see
if that cause it to happen or stop happening
if so you have bad solder in the vertical drive
it should look like an hour glass
Jun 23, 2009 | Televison & Video
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV Blinks on and off
Phil, from your description it sounds like your convergence IC`s are about to fail, the intermittent off/on cycle is because as they heat up there drawing too much current, the bowed collapse tells me it`s the vertical convergence IC that`s the culprit. You need to get a tech out asap to fix this or they could short and take out the power supply as well and that`s just mooore money to fix it, hope this answers your question, BMW Rider
Dec 05, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Mitsubishi WS-55807 TV Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
