Question about Sony PlayStation Portable (PSP) Console
PSP-2001 screen problems
My PSP was showing fine and then one night this weekend while I was watching it about 1 cm of the screen on the right side went grey. It seems like part of the screen died and folded in on itself. Is there an update or a reset button that I can press to fix this? Please help.
  • 1 more comment
  • edj5 Jan 01, 2009
    Have the same problem. All of a sudden, a gray line appeared on the right side of the screen, and the remainder of the screen folded on itself. Annoying!!
  • nowellef Jan 01, 2009
    That is what I figured. From some of the things that I have read on other sites this is an existing problem that Sony knows about and just does not acknowledge. Guess that I will just have to live with it and keep on using it until it dies. Maybe by then there will be something better out. But I might consider changing my LCD screen, will see. Thanks for your input.
  • ccunha615 Feb 14, 2009
    I had the same problem...a thing strip started down on the left hand side then screen started to like jostle and shake then the line down the right side....what's going on???
    Problem Solver:
  • 10 Answers
From what I know, there is no way to fix this... sorry.
Posted on Dec 30, 2008
Hi, i have a PSP3004, firmwire carcked, everything was fine, unless once i removed the battery and reconnected after 15 mins. now i can't view my 8gb memory card on the PC (once connected...
You have to configure your USB connection to PC. What shows up as the drive in your PC when you connect your PSP to it is one of the 4 FLASH folders. Do the following;
1. In your PSP main screen, press your "SELECT" button and XMB Menu will show up. 2. Scroll down to the "USB DEVICE" option. 3. Loot at the value in the right, it should either "Flash 0", "Flash 1", "Flash 2", or "Flash 3". 4. Press Arrow Right until the value changes to "Memory Stick Value".
Exit and connect to your PC again and you'll see your 8GB MS this time...
Jun 09, 2011 | Sony PlayStation Portable (PSP) Slim...
Can you gave me a example of a right triangle problems?
In right triangle we are making 90 degree angle triangle, we can have problem for finding hypotenuse or finding sin or cos values of the side of the triangle. For ex,Find out the hypotenuse,sin and cos value of the right triangle with base 4 cm and perpendicular 3 cm Solution:Hypotenuse = SQRT(4^2 + 3^2) =SQRT(4*4 + 3*3) =SQRT(16+9)=SQRT(25)=5 cm For right triangle, sin(x)=3/5=0.6 cos(x)=4/5 =0.8
Jul 16, 2010 | Super Tutor Trigonometry (ESDTRIG) for PC
Okpsp won't show anything on the screen even when i turn it on
Hi
Make sure the PSP's battery is inserted properly. Press down on the battery release button on the right side of the PSP and then check to make sure the PSP logo is visible and right side up. If you do not see the PSP logo or it is upside down, the battery is inserted incorrectly.
Ensure that the battery is charged,plug it into power and see if it comes on,if it does then all you need do is to charge the psp fully and start using it again
If it still doesnt come on then it might be a manufacturing defect,please call PlayStation support hotline at 1-800- 345-7669.
Jul 01, 2010 | Video Game Consoles & Games
All I get is a blank screen on my 2001 Psp
is a hung psp switch the power slider off then again turn it on ...it should solve ur problem
Feb 09, 2010 | Sony PlayStation Portable (PSP) Console
My touch pad worked fine last night, but now it doesn't! Help!
well, first you should see if it needs charging. Then turn on the ds and touch the little ds on the bottom of the screen. Go to the calibrate or the thing that is on the right side of the person. Try thr test and dont stop it until its over. Try touching the screen again but if that doesnt work call nintendo which the number is in the manual or find it at www.nintendo.com. See if that works.
Dec 27, 2009 | Nintendo DS Lite Console
My new psp go turns on for a few seconds then shuts off. I've charged it all night long and still it does nothing but turn right back off again. When i turn it on all it shows is the time and battery level...
my psp green light comes on i can hear when the psp loads up my game starts to play my screen is black i can't see nothing i can hear my game playing wat can i do to fix the problem someone can u help me my email al_kapone81@hotmail.com
Oct 18, 2009 | Sony PlayStation Portable (PSP) Console
Thin vertical line on screen shows what another part of screen is
Ah, the "line of death."
There sure is & best of all, it's FREE. You will need a piece of tin foil rolled up to a pencil's thickness. You will also need some patience to watch THIS video, which shows you the placement for the tin foil. As pointed out in the video, you only need to remove the face plate & NOT all of the buttons, D-pad.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp hanging
The circle in the lower right hand corner of the PSP screen is showing that a disc is being read. I would say take out any discs you're using and try to run things directly off of the memory card. I'm not going to dive into anything else, because Custom Firmware on the PSP is a tricky situation that you really shouldn't be asking about on FixYa.com.
Oct 06, 2008 | Sony PlayStation Portable (PSP) Console
How to download flash player on to the psp
step by step on how to download flash player 9 on my psp
Feb 11, 2008 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
