Question about Sony Xplod XM-554ZR Car Audio Amplifier
Car amp when i turn the car on the amp light turns green then right to red and stays on red and the wiring must be fine because when i hooked up a different amp and it worked fine
  • bartallen Jan 10, 2009
    hi keefers_77 i took ur advice and when i hooked up the amp without speakers it still did the same thing. and i took the cover off and there is no smell or anything and it doesnt have a rattle. i have 2 12" jbl gt series subs and they arent bridged. i do remember that i had it in a very compact space in the trunk i dont know if that would cause a problem but i am not sure what to do.
  • keefers_77 May 11, 2010
    Try not hooking up any speakers to the amp then turning it on. If the stays green then there is a problem in the wireing.If it goes red again then disconect the amp and turn it upside down and listen for a rattle. If no rattle then smell the amp. If it stinks really bad then something is shorte on the inside. If it dont smell then take the cover off and look for anything lodged on any contacts. Smell the amp again because with the cover off, if it is fried then the overpowering oder of a burnt amp will be more noticeable Are the subs bridged? Make sure that the wires do not make any contact with each other when installed. Let me know how it turns out? Good luck
  • 125 Answers
You have an internal solder jump it must be repaired by authorized dealer or replace the amp at wholesale cost at either way its gonna cost you also try unplugging the RCA's aswell as speakers if still the same repair or change it!
Posted on Feb 04, 2009
2 Suggested Answers
  • 14 Answers
SOURCE: amp turns on and stays on but no sound
are you shure you not connect the amplifier in a wrong connection ...B+,GND,ACC.....ok...then checkif the speakers wires stay in good condicions, some times when we intalled the spk wires for the border of the doors a few times skrewered too.check if it hapen. another ....check if the terminal spk is not going at ground whit the chasis another to....4 ohms per channel ,anny voice coil spk short. good look.
Posted on Mar 15, 2007
Have issues with trailer lights. Both turn signals on trailer flash when I use left or right turn signal. Have 7 pin factory plug. Lights on trailer work fine, hooked up to 97 Silverado. Act funny on 2000...
Standard wiring colors are as follows:
Right Turn & Brake
Left Turn & Brake
Tail Lights
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Jun 26, 2011 | 2001 GMC Jimmy
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
Hooked up to a kicker L712. Worked fine now its in protection mode. When i turn it on the light is green for a second then turns red. It wont stay green. What should i do? Is it the circuit board?
perhaps you are pushing the amp to hard check that the gain control knob is not turned all the way up. This will cause the amp to overheat. If not that check all of the wiring to the amp for a possible short.
Jun 05, 2009 | Sony XM-2200GTX Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
I have a dub 4001 amp
Take it step wise.
Unplug the inputs and outputs from the amp (be sure to mark the wires so you can hook them back up), leaving only the ground, +12, and remote wire hooked up. Now, turn it on. If the amp light goes red, the amp is broken. If it goes green, turn if off, plug in the speakers, then turn it on. if it's red, its a speaker problem, if green, do the same with the inputs, and you'll have your answer.
Jan 22, 2008 | AudioBahn DUB Mag Audio DUB4001 Car Audio...
Amp turns on and stays on but no sound
Mar 10, 2007 | Sony XM-2200GTX Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
