Question about Kenwood KVT-617DVD Car DVD Player
Kvt910dvd I have the same Kenwood head unit and have the same problem with it shutting on and off. What resolution did you come up with? Thanks, Mike Grogan
  • mikegrogan Dec 31, 2008
    Did Kenwood cover it or did you have to buy one? Did you ever find out what the problem was?
I got a new one. hehe
Posted on Dec 30, 2008
Which is the best Kenwood Double Din head units that are available? Where can I buy it.
There are three types of Kenwood double din head units that are present and are very much famous. You can have a name's of this three most famous head units and chose the best option for your car -
1. DDX271 - Kenwood Double din Navigation Head Unit.
2. Kenwood DPX300U Double Din Stereo.
3. Kenwood DDX371 Double Din Head Unit.
This are the three most famous stereo brands that you can chose to get the best brand from Pioneer Head Units that will help you to get the reviews about the products.
Nov 22, 2016 | Kenwood Car Audio & Video
I need a wiring diagram for a kvt-910dvd
heres the manual to download, hope it helps
http://www.retrevo.com/support/Kenwood-KVT-512-Car-Videos-manual/id/13483ag924/t/2/
Apr 03, 2010 | Kenwood KVT-512 Car DVD Player
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp shutting off
your amp is likely over heating.Does it have enough air space around it? You may be over driving it does your head unit have variable out put? if so try lowering the output volume to the amp
Hope this helps...........Good Luck!
Dec 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
2 problems, what are the red and yellow wires on a Kenwood kdc-mp2028? and can you install a used kenwood without the remote?
You can use the head unit with no remote - that's just an accessory. As for the wires, the red is switched power (this gets wired in so that it only has power when the key is on - when the key is off, it turns off the radio). The yellow is constant 12v power (to maintain power to the head unit so that memory settings, treble/bass settings, and the clock are maintained when the vehicle is shut off).
Sep 24, 2008 | Kenwood Car Audio & Video
Forgot unit password for my kenwood dvd/cd unit
Hey there redwood,
Click Here, it will bring to a Tip page authored by one of our best technicians (Robotek). He outlines the procedure for clearing the code on most Kenwood models. This will get you going again.
Remember: Good things come to those who Rate!!
Mike
Sep 05, 2008 | Kenwood Car Audio & Video
Kenwood kvt m700
The unit is clipping which means it's too loud, lower the volume and should be fine.
Jan 15, 2008 | Kenwood KVT-M700 Car DVD Player
Kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD Car DVD Player Logo
66 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
