Question about Denon AVR-5308CI 7.1 Channels Receiver
No sound to surround speakers or subwoofer using denon avr-5308ci. speaker wires and speakers make sounds when driven by test equipment. Connections to AVR look right. What's wrong?
  • 2 more comments
  • GordonMR Dec 31, 2008
    mute is not on - fr, c, fl speakers work.
    if connected to fr, c or fl output, surround speakers work. they do no work when driven by sr a output.
  • GordonMR Jan 01, 2009
    still no surround sound. I changed some settings and the subwoofer came to life. I think it was LFE+main. So, FL, C, FR and subwoofer are fine; surround A R&L, still nothing.
    1. the Denon AVR-5308CI is NOT in "protect mode"
    2. the 7.1 audio processor MAY be faulty. The channel level test (i.e. speaker test with internally generated tones) works for FL, C, FR and subwoofer, but not SAL and SAR. Is this still likely?
    3. the speakers are NOT faulty. All speakers (including the surround speakers) work when connected to the front channels. No speakers work when connected to the surround channels.
    4.the audio signal 7.1 compatiblity is not an issue when using the channel level test.
    Thnaks for your help.
    still need help
  • GordonMR Jan 02, 2009
    I did all those things - still stumped.
    Genius:
  • 1,199 Answers
Check the speaker selection switch!
Posted on Jan 02, 2009
    Genius:
  • 1,913 Answers
Check all conection may be some problem in connection checkl all jack
Posted on Jan 01, 2009
    Novelist:
  • 146 Answers
Are you running the receiver in 7.1, 6.1 or 5.1 mode? Some units need to be set up for multichannel operation depending on the speaker configuration. There should be a setup menu that allows you to set the receivers speaker configuration. In 5.1 mode you should use the side surround channel connections for rear speakers as the rear surround channel on 6 and 7.1 systems are not discreet channels, and are mono. You also have to tell the unit that there is a sub hooked up. That is also in the setup menu on the unit. Refer to the owners manual for instructions on accessing the setup menu.
Cheers and best wishes.
Shayne Schecht
    Guru:
  • 558 Answers
Look like they are worn out, now you need to buy a new one.
Posted on Dec 31, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of possibilities:
  • the Denon AVR-5308CI is in "protect mode", but that would mean that there is some sort of indication that it is so such as a blinking LED light or the message/word "PROTECT" on the display panel;
  • the 7.1 audio processor is faulty (most likely), any selection/choice would result to no audio. Perhaps you could try without any enhancement, Dolby or Sound processing and see if it works;
  • the speakers are faulty (highly unlikely), you have posted that they were tested and would be very rare for all to go dead simultaneously;
  • the internal power amplifier or some other circuitry/electronics are faulty (unlikely), unit wold have gone into protect mode since it will sense the hardware fault;
  • the audio signal source is not 7.1 compatible (a possibility).
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Dec 30, 2008
  • Louie  Role
    Louie Role Jan 01, 2009
    Appreciate the postback and update to which I believe we have now a common most likely suspect, the "7.1 audio processor" which is responsible for funneling all sources/input through it, applying appropriate filters, enhancement, processing and outputting to the preamp/amp stages.
    Unfortunately, often not a component level repair but board replacement.
    Genius:
  • 1,550 Answers
Just check the settings whether you have selected mute .
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
I have a Denon AVR-2801 that I have owned for many years with almost no problems. I have 5 speakers and a subwoofer connected to it - the speakers are connected through the wire inputs on the back and the...
Maybe start with speaker test tones to verify the hardware instead of messing with live audio modes.
http://www.retrevo.com/support/Denon-AVR-2801-Receivers-manual/id/363bh831/t/2/
BTW: the powered subwoofer is supposed to be driven by the 'Subwoofer' Pre-Out.
What input are you using that allows audio when you select EXT IN AND the other modes? That is a specialized analog input for 5.1 analog equipment ONLY. (Page 32)
Aug 14, 2011 | Denon AVR-2801 Receiver
I purchase a denon AVR-591 & now i am using speakers from a kenwood home theater system but know all of the speakers work except the subwoofer does not, know the swbwoofer input has a wire Plus Minus...
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Feb 26, 2011 | Audio Players & Recorders
No sound
check speaker conections. disconnect all the speaker wires and use one speaker that you know that works and connect it to each channel one at a time. most surround sound stereos will not go into surround mode unless all the speakers are connected so make sure stereo is in 2 channel mode to start testing. check all fuses sometimes amp fuse is seperate from power circuit and denon uses relays in 99% of thier units.
Dec 23, 2010 | Denon AVR-2802
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Jul 18, 2009 | Denon AVR-1706 Receiver
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Denon AVR-5308CI 7.1 Channels Receiver Logo
90 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
