Question about GE GSS20IEP Side by Side Refrigerator
To much water injecting in ice maker
My ice maker mod#gss20ie ma is putting to much water into the tray
and causing it to run over thus freezing the ice into a great big clump
i need to know how to adjust the volume of water coming in to the tray
if possible
  • 115 Answers
You can not adjust it enough if it is overflowing I would try a new water valve first cause it is cheapest but if it dont fix it then get a knew icemaker
Posted on Dec 30, 2008
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ksrp25fnbl00 Ice maker stopped producing ice
ksrp25fnbl00 ice maker has stopped making ice. It appears that the water supply that comes down from the top of the interior cabinet is freezing and this is causing the ice tray not to refill. What would cause this?
Jul 09, 2012 | KitchenAid KSCS25FKSS Side by Side...
On my VISB542SS the ice maker , water leaks into the drawer when ice is being made, Ihave removed the unit to check for leaks bot find none.
The ice tray releases the ice because the mechanism twists the tray during the end of the cycle. Sediment builds up in the ice try over time and the smooth Teflon surface is no longer smooth, and the ice can get a "grip" on the tray. Then when the tray is twisted, a few cubes remain in the tray. When the measured amount of water then flows into the tray on the next cycle, it is too much. It freezes over the top of the tray, and the next time the tray is twisted, no ice falls out. When water is injected after this, it just runs off the top of the tray into the bin, freezing the ice in the bin. Replace the ice tray every 3-4 years with a new ice tray, and the problem disappears.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Oct 15, 2010 | Viking Refrigerators
The ice maker in my samsung fridge is putting too much water into the ice tray thus dripping water into the ice compartment and freezing all the ice cubes together and dripping through the outlet
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray is supposed to catch the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Jul 17, 2010 | Samsung RS2578BB Side by Side Refrigerator
No water in ice maker mold
may have a bad valve . but try this first . put about 6 to 8 oz of water in icemaker / when it freezes it will call for a harvest. / if it dumps the ice cubes / at this time the ice maker will call for a refill . if valve is ok it will refill . also ck the water inlet tube to the ice tray . they some times will freeze with ice thus blocking the water fill. hot water up the tube will correct this problem. hope this helped .. mm feed back pls ..
Feb 04, 2010 | Refrigerators
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
