Question about Jensen CD-515K CD Player
Jensen CD515K volume control
I have a Jensen cd 515k stereo and for some reason the volume control stopped working. It wont turn up or down. does any one know how to fix it or do i need to get another face plate?
  • pioneerboy May 19, 2008
    my volume knob stopped too but my display is out with it what do i need to do. i wanted to take it apart and look and see if something come apart but i didn't so i went back to pioneer head unit
4 Suggested Answers
The Marv
  • 72 Answers
SOURCE: Lost face plate
Ebay
Posted on Jan 06, 2007
MonsterG
  • 52 Answers
SOURCE: car stereo
if u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Posted on Feb 11, 2008
SOURCE: Jensen CD3720 car stereo unit face plate LCD display blanks out.
The substrait is probably cracked, that's the circuits inside the pc board of the faceplate. It will cost you too much to try to have it repaired. If you will wait for a few days I may have a face for it as I'm currently trying to fix one that is blowing fuses. I'm not going to spend a whole lot of time on it. I'll let you know.
Posted on Apr 08, 2008
How do I turn off the outside speakers on the Jensen JCD2010 installed in my travel trailer?
Press the volume control to access the audio menu. Navigate through the audio menu by pressing the volume control button repeatedlly until you get to Fader. Then adjust the Fader to by turning the volume button to either 9R or 9F. In my trailer, 9R is for inside listening, only.
Jun 15, 2014 | Jensen JCD2010 AM/FM/CD Stereo
Car radio is blasting loud when first turned on.
That is imposible buddy.Before you get out of the car turn it down.Then you should not get a blast when. you hit the power button to turn it on.
Oct 22, 2012 | Phase Linear Jensen PCD161A In Dash CD...
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Jensen 9412
how can I restar a stereo car jensen vm9412
May 29, 2008 | Jensen VM9510 Car DVD Player
Car stereo
Feb 11, 2008 | Jensen CD4610 CD Player
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Volume resets to 26 every time unit powers on
Jensen Units donot remember your previous setting, its just one of the many reasons not to get one
Mar 27, 2007 | Jensen VM9020TS Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Jensen CD-515K CD Player Logo
79 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
