Question about HP Pavilion M9040N Elite Desktop PC
HP Pavilion m9060n (Vista Premium) networking issue
I've disabled my firewall and still can't send or receive files from my XP Pro laptop. I can see the files (and all rights are open on the XP machine) but if I try to download or upload FROM THE HP the machine locks up. Explorer locks up so tight that when I "down" it from Task Manager and it comes back, "COMPUTER" is still locked. The only solution is a reboot...and the machine in that mode won't shut down nicely either, requiring holding the on/off switch (it said "logging off" when I went out to dinner and was still "logging off" when I got back).
By the way...if I do the transfer the other way (in either direction), it works fine. Also, when uploading very large files over the Internet (think a 250M file sending to YouTube) it gets stuck; the same file from the XP machine on the SAME router uploads fine in 3 hours. My gut tells me that these two problems are interrelated.
I don't think it matters but the HP is connected wirelessly (all Internet nd local network protocols appear to work except heavy-duty file transfer) and the XP machine (a Qosmio laptop) is wired to the router. The reason I don't think it matters: a file pulled from or pushed to the HP using the Qosmio works just fine!
  • ljaygould Jan 08, 2009
    All Norton software was uninstalled when I purchased the machine. I use CA firewall (but as noted I disabled it and the problem persists). Help!!! C'mon guys, I paid for better than this!!!!
    Genius:
  • 1,239 Answers
Hi
I had a similar issue whereby within the first five minutes of turning on the DMA that it would lock up (regardless of activity) and the only way to fix it was to reset it.  Not sure if you are seeing this based on your description, but I worked with Linksys support for months and found out that it was my cable provider (Armstrong Cable).  They are sending some very odd traffic that the DMA absolutely does not like and no one could figure out what it was.
In the end, the only workaround is to create a rule on your router for access restrictions and restrict the IPs of your DMAs from being able to see the outside world.  The DMA can still connect to your PC and work fine, they just can't get product updates, etc.  So, to get updates, when you boot your DMA up, wait about an hour, and then you can turn off the restriction on your router and the DMA can then get updates successfully.  Also, any time you power down your DMA you must enable the restriction if it has been disabled.
Not sure if this will help you any, but your issue sounded "close" to mine.
Posted on Dec 30, 2008
  • 39 Answers
Hi Ijaygould,
How about if you wired all to the router.
If no problem then perhaps you should check your wireless router configuration. cable is still faster than radiowave :)
And also test in reverse position, if Qosmio/XP in wireless and HP/Vista in wire, what happen ?
Btw, do you ever have a working situation before or your HP/Vista is like this since the beginning (with your mentioned scenario ofcourse) ?
Hope it helps :)
Rgds,
Jeff
  • 395 Answers
If you still have the norton trial installed then get rid of that as the norton firewall is a pain.
Bios
clayton have you changed motherboard ?.you can use the RAM your motherboard are built for.
Apr 27, 2013 | HP Pavilion Elite M9060N PC Desktop
I've just set up a wireles network at home. My desktop and laptop are conected to a Belkin router. Th desktop has McAfee firewall etc installed. I think I've done everything ok on the set-up. When i...
ok you will have to set up printer and file sharing on both machines. not to familiar with vista but its similar to xp. if you open my computer or windows explorer right click on the folders you want to share. the Macafee thing not to sure but you should be able to make an exeption for file and printer sharing
Jan 03, 2010 | Computers & Internet
Vista laptop does not see HP cpu on the network. It does see all the other cpu's but not HP. All other's including the HP are XP based. All are on the same Workgroup. I can ping each other and it responds...
You may wish to consider running the set up a network wizard to ensure file sharing is enabled on the HP machine, making it discoverable to the vista laptop.
Sep 22, 2009 | HP Computers & Internet
Change operating system
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
Jun 15, 2009 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Unable to ping my ISP gateway
This could be an issue having to do with the installed drivers for your network adapter. XP and Vista use different drivers, even though the hardware is the same...Take a look through this tutorial and make sure all your network hardware has vista drivers installed. Also possibly helpful would be a read through of this vista help site...
I would start there, and if you need further assistance after making sure you have the correct drivers for vista, write back and we'll be happy to help you sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 11, 2009 | Microsoft Windows Vista Home Premium with...
Vista Laptop cannot connect to XP users
go to control panel>>add and remove prgrams>>click on add/reomve windows components on the left panel.
make sure you have the system CD.
put a check mark in "networking services" and "other network files and print services" install the addtional services.
check the share volume, make sure you have given the user rights to access the drive.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Taking Time to Print
that is a network problem between the laptop and the PC. Look for your network settings and adjust them.
Use a tool like pctools to identify your network problems. Vista and Xp sometimes have a problem
Apr 19, 2008 | HP Pavilion dv6000z Notebook
Sharing a printer between a Vista Home Premium and XP Media Center Computer
Hi cavman6
(01) Is the Vista computer able to access ANY shared resources at all on the XP machine?
(02) Are you running any firewall software (other than the firewall built into the operating system) on either computer?
(03) If you are, please, let us know which firewall software it is and, for now, please, disable it.
(04) Do both these computers have Internet access? (I'm assuming they do but I do need to ask.)
(05) Is the printer currently ONLINE and working properly w/ the XP machine?
IF YOU HAVEN'T DONE SO ALREADY, PLEASE, DO THE FOLLOWING:
(06) Assign *both* computers to the same network WORKGROUP.
(07) Ensure that file and print sharing are enabled on the XP machine. If you'd like, do so on the Vista system, too.
(A) How to on Windows XP
(B) How to on Windows Vista
(08) "Share" the printer on the XP machine (in printer properties).
(09) Can each computer now see itself AND the other computer on the network?
(10) Have you added your user name and password that you're using on the Vista system to the users list on the XP system?
(11) If you haven't done so already, please, do this. The user name should have a password associated w/ it. So, if you aren't using a password on your Vista system profile, assign one then add that user's credentials to the users list on the XP system.
Please, post back here w/ what you've tried and the results, your observations and any other comments or questions.
Thank you
BJ @:)
Apr 15, 2008 | Extended Systems Printer Sharing...
HP Pavilion M9040N Elite Desktop PC Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
