What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work.
I suggest, you use the laptop to format your card. The process is as follows.
- Insert the SD card in the SD Card slot available on your laptop. Enter My Computer, and right click on the icon which represents your card. Format it from there as you would do for any other USB data storage.
If you don't have a laptop, or your laptop doesn't have the SD Card slot. Then, you should purchase an SD Card reader. The process mentioned above would be similar.
If all fails. I recommend you to get another card, as the card may have been corrupted.
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Ok try this for you to determine if your memory card is defective or not, try to insert your card to a device that support the type of memory card you have. Then if it still doesn't work i assume your memory card is defective. But if the memory will work try to insert other memory card on your camera for you to determine if your camera memory slot has a problem.
Reply to this post post if this helpful or not and dont forget to vote
Tnx for using Fixya
