Question about Alpine TDM-7543
Is it possible to install a cable to use it with an mp3 player?
Due to the fact that the radius has a CD Shuttle Control, instead of it, is it possible to connect an mp3 player?
0 characters
1 Points
I dont understand how to play mp3 player on my kenwood cd player.I have the cord to hook it up to my kenwood radio but i dont know how to get the mp3 to play.
Just plug the cord into the front of the cd player where it says "AUX" and then plug the other end of the cord into the headphone / line out jack on any ipod or mp3 player then select "AUX" instead of CD and the sound will come through the system
Jun 02, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
I can't get the CD to eject.... in fact, I can't get the unit to acknowledge there is even a CD/mp3 option... IT just flips back and forth between tuner and aux. It was cold last night when I put a Cd in...
When you remove the faceplate you will find a small little black hole in the deck.Insert an opened paperclip to over ride the eject and make it come out.Please let me know if this helps
Jan 19, 2011 | Clarion CZ200 Car CD USB MP3 Player
Ok...I have an Alpine CDE-9845 and i wish to play my ipod by using an aux cord but i have no clue where to plug it in at
You will first need an audio cable that has a 3.5mm male end on both sides of the cable.
You will plug in one end into your mp3 player, and the other end into the 3.5mm audio jack on the front of your cd player. On rare occasions its on the back of the cd player.
Then instead of putting your cd player on the radio, or cd, the other option will be Aux. Start your mp3 player up and you should be able to hear it on your car audio system.
This is the standard setup for running an mp3 player through your car stereo. Thank you for choosing Fixya!
Aug 10, 2010 | Alpine CDE-9845 CD Player
Problem for Blaupunkt Bermuda MP36 Car CD Player. I was getting the error CD error when I use to insert the mp3 cd in the CD player. I complained and was asked to reset it by disconnecting the battery...
It is possible that if your normal standard recording are working fine, then the format of the MP3 is not recognised. If so please try and rerecord on the acceptted format. If this MP3 was playing earlier to the fault then it is a possible failure of the processing section. If your cd is not reading but ejecting out then it is a fault in the optical for a possible weakening of the the laser. If you have warranty claim for this failure. however if it is readding but there is no output please check as above with a standard mp3 format. Howeverr if there is sttill no result I beileve you will have to get the main board replaced. If you are familiar with electronics you have to check within for the RF and signal to confirm for the suspected stage. however attempt only if familiar. Hope you follow this guidance. Good day
Jul 13, 2010 | Blaupunkt Bermuda MP36 Car CD Player
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
Jul 12, 2010 | Blaupunkt Bermuda MP36 Car CD Player
Do i need to buy a cable to run my mp3 player on cd player
Hello jaredsmick,
Yes, you should be able to plug your MP3 player into the DEH-P3700. You will need a cable. While I'm not certain as to what type of output jack your player has, it's most likey a "mini-jack". Here's a link to what it looks like:
You'll also need to make sure that the "AUX" source is turned on in the Pioneer. To do this, press FUNCTION repeatedly until AUX appears in the display. Press up/down to turn ON or OFF and the status will be displayed.
Hope this helps.
Apr 22, 2009 | Pioneer DEH-P3700MP CD Player
Cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Jan 27, 2009 | Blaupunkt Louisiana DJ32 Cassette Player
How to make mp3 work on DEH P3500 ?
when it says mp3 it means you can hook an mp3 player to the stereo and play music that way. if you have an mp3 player you need a cable that will hook the mp3 player to the stereo and you can get that cable from pioneer.
Nov 16, 2008 | Pioneer DEH-P3500 CD Player
XDM6825 Not Playing MP3s in Stereo
if you have a FM MODULATOR installed too,some ones no transmiting in stereo mode, try changeit
Feb 14, 2007 | Dual XDM6825 CD/MP3/WMA Player
Car Audio Receivers Logo
23 people viewed this question
Top Alpine Car Audio Receivers Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio Receiver Expert? Answer questions, earn points and help others
