RUN DLL ERROR LOADING C:/windows/system32/OVTFboot.dll The specified module could not be found Having same problem during installation of 35mm slide scanner. Managed to download a copy of OVTFBoot.dll from "Driver Agent" but install failed again with message: "Missing entry: OV550Start" I suspect that the correct driver is not included on the installation diskette provided by the manufacturer. Having same problem trying to use VuPoint Solutions FILMSCANNER FS-C1-VP...also unable to unzip driver downloaded from their website.
  • DianeDD Jan 09, 2009
    Tried that...haven't received a reply back yet. Any other suggestions?
  • 8,596 Answers
There is software that is supposed to come with the 35mm slide scanner called OVT Scanner. If you are running an Operating System other than XP, it will not install no matter how hard you try. The company has not developed a fix for the Windows Vista issue. If you are running Windows XP, go to Start -> Control Panel -> Add/Remove Programs and see if OVT Scanner is on your program list. If it is, uninstall it, then go to the VuPoint website and reinstall the OVT Scanner software. If it is not installed, go to the VuPoint website and download/install the OVT Scanner program.
The VuPoint FS-C1-VP is completely incompatible with Operating Systems other than Windows XP – if you are running Vista, the installation will not work. If you are running Windows XP, download the evaluation version of WinZip so that you will be able to unzip the file containing the correct drivers.
Hope this help!
-Tha Mp3 Doctor
Posted on Dec 30, 2008
    Guru:
  • 731 Answers
Hi Diane
May i know the manufacturer of the 35mm slide scanner?What you suspect must be correct, files are missing in the disk.
  • 395 Answers
You can download a copy of winrar from www.rarlabs.com and that will unpack zip files also.there is also a driver here
http://cameras-and-mp3-player.free-driver-download.com/url.php?id=TmpFNE5qaz0&link=0
  • 13,433 Answers
Contact the maker of the scanner for the correct file, they will most likely send it to you and get it working.
Drivers for product
are you missing a file ovtfboot.dll (if i remember correctly) mine was damaged as well, you can download the full driver file from Vupoints werbsite driver page
Sep 28, 2010 | VuPoint FSC1VP
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
Driver stiaspi.dll not found
http://www.fix-all-dll-errors.com/stiaspi.dll/
This will fix the issue without any botheration. :)
May 26, 2009 | AcerScan 620P Flatbed Scanner
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Feb 23, 2009 | Canon DR-9080C Path-Through Scanner
OVTFBoot.dll
OK ya must be trying to install into Vista? anyway whats happening is ya NOT using Admin mode... and that DLL isn't being allowed to be put in the system32 dir... so disable UAC open admin prompt and find it, & copy .. so after ya install find the DLL on the install media .. then copy and paste it to ya windows\system32\ dir.. register it if reqiured should be all good.
Better still install properly with admin rights and such. GL
Jul 29, 2008 | Office Equipment & Supplies
Trying to make a copy- worked last week?
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Jul 15, 2008 | Canon CanoScan 4400F Flatbed Scanner
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Well I had a code 15 error with mine LIDE 20. Apparently the scanner needs a certain amount of power to run off the USB port. So I changed the USB port and problem fixed
Feb 16, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
667 people viewed this question
k24674
