Question about Dacor Preference RSD30 Gas Kitchen Range
When we have a power failure, should the "sparker" still work?
  • 115 Answers
The spark ignitor will not work when the power is off cause you have to have 110v to work it but you can light your top burners with a match
Posted on Dec 30, 2008
Baxi he 24 solo. Local Gas safe Engineer has replaced pcb, condensate trap, overheat and other thermostat, also igniter/sparker and flame failure sensor, Boiler still intermittently locking out (red...
Sounds like its an intermittent flame failure on trial for ignition. Look for the pilot flame drifting away from the sensor when the main valve opens.
Nov 24, 2013 | Heating & Cooling
Sparker doesn`t work on wok burner, i have replaced it but still doesnt work, it does spark if you place a screw driver from sparker across to the ring
sparker sounds like its ok but its sounds like it needs to be adjusted a little so it can ground out to cause the spark you need
Apr 08, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Igniters not working
Hi.
Either the single ignitors are faulty, or the ignitor sparker module must be replaced.
The sparkers are tested energizing them.
The ignitor hub module is located under the cooktop panel.
Check also the wiring harness to spark module.
Here all parts and diagrams for your range:Parts & Accessories.
Regards.
Mar 02, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Model 790, propane, right rear will not light, piezo sparker works, seems like no gas to that one burner- ( the simmer )
i have a kenmore gas range when i turn front and rear burner no light but i can hear the sparker and smells the gas. any suggestions?
Jan 21, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Only the infared burner does not ignite.
If you have a push button sparker the wire may be off or the sparker may be worn. You can check for spark when it is dark out. If you dont think you have spark then try to light the burner the "old school" way just hold a match or flame to the white area and then turn and hold the gas knob. If you can light it the old school way then its your spark. I would remove the sparker (unscrew the plastic nut on it remove the wire if its stll on) and test it on your hand. If the sparker works you will know because you will get a shock from the end of it. If you dont get a shock then you need to buy a new one. I hope this helps
Feb 02, 2009 | Dacor OB36 Gas Grill
SPECTRA GE GAS STOVE
Try cleaning the sparker with file to better the spark. If you can adjust the angle of the sparker closer to the gas nozzle would help to.
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't believe so. It is usually electric powered. You should be able to light very carefully with a match by lighting the match first and then turning the gas on slowly with the match up close to the burner.
Dec 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Kenmore Ultra Bake. Gas won't come on
Loc is a child lock
1)press lock/unlock button for 5-10 seconds
2) set the clock
hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dacor Preference RSD30 Gas Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
