Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Green light flashing
No. Everything was fine other than the message saying the lamps life has expired. then one day the tv was not turning on. I looked at the lamp and it was bad. After putting the new lamp in is when this problem began. I plan to open up the back tomorrow and look at the capacitors. Do you know where I should look for this DM module. Also someone else has said the chassis needs to be rebuilt. What do you think of this?
  • 179 Answers
The DM is the board that has the cable card slot on it. to get to it you have to take out the chassis (you can find instructions at www.tv-techs.com) take off the shields (be carefull they are sharp) take off the terminal board, and the FMT board, and there it is.
while you have it apart chech the caps on the power board and the FMT board for pregnant caps. sadly, replacing the 1000uf caps only corrects about 1 in 10 sets.
Posted on Jan 04, 2009
I have a 50ml6200 magnavox. I have changed the bulb twice and tv had worked fine. Recently had our floors done and had to move tv out to shed for a couple of days. Brought tv in worked fine. Needed to move...
the tv got dust when placed out say u need to clean the inside of the light engine, the lamp too but be careful u must use only methylated spirit with a new soft dry bristle brush caution if u touch the lamp with your hands u will shorten its life. the color wheel inside the light engine needs to be cleaned the same way too make sure u do not spill any thing in the components and of course the tv must be off nand left to dry before restarting
Jul 08, 2013 | Televison & Video
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
I turn the tv on and the sound comes on but the screen stays black. Everything is plugged in correctly and all the settings have not been touched.
The LED indication light on the front screen bazel panel said "LAMP" light up or flashes?This tv the projection lamp been in use like 4 or 5 hours a day of watching tv,the lamp been in the tv use like a 1 1/2 or 2 years inside the tv in use?The Lamp life is over,the lamp reqiure changing.
Jun 24, 2010 | Hitachi 43FDX01B TV
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My sony KDF-50E2000 TV has screen message coming up that says projection lamp life is expiring, is the XL2400 the proper replacement and will that correct the problem
Yes XL2400 is correct number. Replace Lamp message is a timed message that will reset and turn off if you unplug TV when lamp is removed and replaced.
Mar 02, 2010 | Sony KDF-50E2000 50" HDTV
Lamp red light is on when tv is on and not flashing tv info says solid light is lamp life expired but tv is working fine is this a problem.
It's only a problem when you try and finance a new bulb ($400.00 for mine). But seriously, the only "problem" is that an older bulb exhibits much lower light levels and the picture has crappy color, brightness and contrast. Keep a coffe can around and put a few bucks in it everytime you watch it. when the bulb finally blows you'll have a couple hundred bucks in there towards a new one. (a little easier to handle)
Packman
Sep 08, 2009 | Akai PT4298HD Rear Projection Television
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
