Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound no picture, the stand by light blinks four times
I switch off power to the unit. After a few sconds when I switch the power back on and trun on the TV the green status light comes on for about five seconds and goes on to stand by mode and starts blinking. It blinks four times in two sconds.
  • 5 more comments
  • tekeste takeye Dec 31, 2008
    Greatings Guru,
    Thank you for the information, Your diagnostic is right on. But when I bought the TV in 2006 I bought Extended warranty which is good until 2010. If I remove the cover off the TV to get access to the inverter board and the power supply.It will void my warranty.
    I know your solution will fix my problem. I am going to try to get it fixed with waranty. I paid $ 500. for the extended service contract I better get some thing out of. Thank you.
    Any of you guys with a problem like mine if the warranty is expaird use this solution.
    Thanks again Guru
    Kind regards.
  • jrs2slow Jan 21, 2009
    I have the same problem and am getting the run around by the circiut city extended warranty people. So good luck.
  • redcal7 Jan 26, 2009
    I have the same TV and the same problem. We bought our TV on black Friday in 2006 from Circuit city. Our warranty now belongs to a third party too. They are claiming to "not be up and running at this time". They told us to call this # which is just a recording telling you to fax in your info., no response! What is the solution? I didn't see it. We are obviously screwed, these people are not going to honor our warranties for a company that doesn't exist anymore.  Please help!!!
  • Anonymous Jan 26, 2009
    Yes the same problem
  • bkdg100 Mar 13, 2009
    No sound no picture, the stand by light blinks four times" problem, and notify you when a new solution is offered.
    service manual and trouble shooting guide
  • highoptional Apr 28, 2009
    Same deal with the 4 red flashes, but I got mine from afriend so When I take off the back cover what do I do?
  • atynan27 Apr 29, 2009
    tv turns off by itself, and standby light blinks 13 times. tv was purchased 11/07.
    New Friend:
Check the voltage across +25 volts source also check if the horizontal transistor is good. Goodluck.
Posted on Nov 22, 2013
  • 2,326 Answers
If you have the above model, then the four blinks indicate a backlight failure. The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing.
Let me know if you require further assistance.
Posted on Dec 30, 2008
  • Jaime Hernandez Dec 31, 2008
    Since you have the extended warranty, I would suggest to use it instead of opening the back cover, that might void the warranty.
    Good Luck.
  • Bret Wery
    Bret Wery Dec 01, 2010
    What wire do I check for the 24 volts?
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Sony tv kv ha21p52 the picture is shrinking in bottom few seconds the set goes to stand by the led bilinking four times plz help me
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 23, 2014 | Televison & Video
My sony trinitron model kv-27S42 has no picture/sound, keeps clicking and the Stand by/Timer light keeps blinking. I have disconnected it for the night, plugged it back in but the problem remains? any...
Blinking of standby light in Sony TVs are fault indications. You just count the exact number of blinks occurs at a time after switch it ON. Switch it ON and OFF by its front panel power switch, and not by the remote control handset. Do this for at least four times, count the number of blinks, confirm and inform me. I can then locate the fault section of your Tv, seometimes even to the exact point of fault too. OK
Happy New Year
Dec 31, 2010 | Sony KV-27S42 27" TV
XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
May 30, 2009 | Sony KDS55A2000 55" HDTV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
744 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
