How do i chg a port number
I wan to chg the port number to 8888 but i dono how help me pls
  • Adam Creswell
    Adam Creswell May 11, 2010
    What exactly would you like to change the port number for? The web interface for remote administration?
    Problem Solver:
  • 17 Answers
Port 80 will most likely be the port for internal access and often can not be changed. External access (if allowed) can usually be changed within the web configuration screens.
Posted on Jun 05, 2009
Utorrent port blocked
enable https inspection, then try to block the respective sites
Jan 06, 2014 | Fortinet, Inc. Computers & Internet
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
Error code E000732 8888
i have irc5185i it show e000732-8888 pls help me
Oct 06, 2012 | Canon imageRUNNER C3200 Copier
How to hook wired router to cable box. What is WAN outlet
all of your computers should get hooked up in ports 1-4 and the WAN port should be hooked up to your broad band router from your internet service provider. so if your first computer is hooked up to port 1 just plug your second into port 2 and every thing will work fine.
I hope this helped.
Thank you,
Norse
May 18, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
Progress: -------------------------------------------------------------------------- Checking Http URL: http://87.56.179.75:8888 ... Error! Checking Stream URL: http://87.56.179.75:8081 ... Error!...
Hi friend,
We have to open the port numbers in your router for the above eroor check sum,follow the below mentioened steps,
1.Type 192.168.2.1 in the Internet explorer,You will get a belkin router setup page
2.On your left hand side,click on Firewall,it will ask for password,leave it blank and click submit
3.Change it to disabled and click on Apply changes
4.On your left hand side click on Virtual servers
5.Put a "Check mark in 1st box",in "description type as Streaming" in "Inbound port put the numbers 8888" and in the "type select as TCP and UDP" and in "the Private IP address type the ip address of your particular computer in which you are getting this error message" and the Last Outbound port,type the number 8888"
6.The same for the second one but the Type is TCP and the Inbound and outbound port is 8081
If u have any clarification feel free to provide th reply
Regards,
Ayyasam
Feb 27, 2010 | Computers & Internet
How to set port forwarding?
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
Click the Firewall button near the top of the page. Use the Protocol drop down box to select the protocol type of the ports you are forwarding. If you are forwarding a single port, enter that port number into the LAN port range, Left WAN port range and the Right WAN port range boxes. If you are forwarding a range of ports, enter the lowest number of that range into the LAN port range, Left WAN port range box. Then enter the highest number of that range into the Right WAN port range box. Enter the IP address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. When you are finished, click the Add button.
When you're finished, click Save near the bottom of the screen to save your changes.
And that's it! You're done! Hope this helps.
Dec 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Help me
Go to the routers setup page. (go to the computer it is hooked up to and type in 192.168.1.1 in the browser bar) go to the port range forwarding section. and enter the necessary information. DONT FORGET TO SAVE! =]
Dec 30, 2008 | Computers & Internet
Help Me pls i wan to chg the game port number to 8888. the game tuttirol ask me go thie websitesite. portforward.com so wat should i do now ?
- Game port 8888??
- No its impossible to use the port....
- It is not in range to basic ports (3000 something only)
- The 8888 is invalid...
- You can use 888....
Dec 30, 2008 | D-Link AirPlus DI-524 Wireless Router
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
