Question about SanDisk Sansa e250 MP3 Player
My sansa won't turn on and it is fully charged
My sansa is charged but it dosent turn on
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    My sansa clip was working yesterday and when i woke up i turned it on and the lights started blinking and it shut down what do i do?
    Try Fully charging the most electrical equiptment have a reserve built in its battery so you are able to switch on by going off again Batteries need fully charging. If you have done this then your battery does not hold its charge Sorry but they need replacing.
    May 22, 2010 | SanDisk Sansa Clip MP3 Player
    Why dosent my sansa turn on? its even charged
    The power button might be broken.
    Hope This Helps,
    kaleb
    Nov 16, 2009 | SanDisk Sansa Clip MP3 Player
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Computer in Hibernation mode
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    Sansa e200 2gb is countinously restarting
    OK TRY THIS...Turn unit on and allow to completely run dead.Allow to fully charge.this should reset and no more constant reboot.Please allow to fully charge.Do not rush this process.RICHARDM69
    Jan 07, 2009 | SanDisk Sansa e200 MP3 Player
    Sansa Clip not holding charge
    Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
    Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
    It wont turn on !!!
    My Sansa won't turn, and its been giving me a lot of difficulties since I bought it. It just turned off and like died. It won't turn back on. HELP!!!
    Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
    Charging the Sansa Clip player
    If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully charge...it should take a couple hours to charge the device....
    Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
    Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
    C200 dont charge
    Try changing the battery.
    Dec 16, 2007 | SanDisk Sansa c200 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    32 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
