First check to see that your keypad is unlocked. You can lock/unlock the keypad by holding in the PTT button for three seconds. You will see a little lock icon when it is locked. To set the code for a channel: 1. Press Menu until the CODE number begins to flash. 2. Press the + or - to select the desired code. 3. Press the PTT to save the code. Note: You can set a different code ofr each channel using this procedure. Zero (0) equals OFF. If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios. Best regards.
SOURCE: how to set interference eliminator code on motorola two way radio
The FV300 does not have the interference eliminator code feature. (Sorry)
