Question about RCA D52130 52" Rear Projection Television
RCA D52130 52 in. Won't Display High Def
I have tried connecting a few different HD devices (an XBOX360, an HD DVD player and now a PS3) to my RCA D52130 52 in. HD-ready TV and whenever I configure the component for anything other than standard definition, the screen goes blank or has wavy lines. Basically, it's like the TV doesn't know what to do with the HD signal. It can only display properly if the device is configured for 480p, nothing else works. The specs in the TV's manual say that it is an HDTV monitor capable of 1280 x 1080 interlaced resolution. It is outfitted with three sets of the standard s-video/composite A/V jacks, one set of component (Y-Pr-Pb) video jacks and one 15-pin D-sub high resolution input port. I have tried connecting the TV using both the component video jacks and the high resolution video input but neither setup seems to work. The instruction manual is here: http://157.254.235.130/public/15719660.pdf. Page 63 gives the rest of the specs for the TV. I've tried contacting RCA but they have been absolutely no help. Has anybody else had this problem? Is the TV too old (about seven years) to be compatible with the latest technology? I would just like to know if I should pursue getting the TV fixed (if anything is even wrong with it) or if I should consider replacing the TV altogether if I really want to enjoy the benefits of HD.
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Posted on Nov 05, 2010
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Tip
How to Convert DVD to HD H.264?
Part 1: What video file extension provides the best quality when converting DVD?
c10b0c3.png What file format to convert DVD to save as much of the video/audio as possible. I know that converting it into any format will decrease it's quality, but which will preserve it the best?
ac96872.png Convert DVD to HD H.264 Movie (including H.264 Transport Stream Video with HD standard, H.264 TRP Video with HD Standard, and Apple's Quick Time video with HD standard).
What's H.264?
H.264 standard, the state-of-the-art digital encoding format for high definition video, is a high quality video compression algorithm and is suited for all types of applications with different ranges of bit rates. In addition to MP4 files, H.264 compressed video data can be stored inside AVI or OGG files with the option of saving the file with or without the audio data. The technology is also known as AVC (Advanced Video Coding) or MPEG-4 Part 10 (ISO/IEC 14496-10).
Why to convert DVD to HD H.264?
Well, to make a long story short, H.264 provides powerful compression technology that delivers a superior video experience at a low bit rate. Its flexible bit stream control enables H.264 to deliver high-quality video to a variety of devices ranging from low-powered cell phones to high-powered Blu-ray devices. In a nutshell, H.264 is suited to any platform-handheld to high def.
Which Player software supports the HD H.264 file format?
For HD H.264-TS video (*.ts)--VLC Media Player;
For HD H.264-TRP video(*.trp)—Windows Media Player
For HD H.264 video (*.mov)—Apple Quick Time Player.
Part 2: How to Convert DVD to HD H.264?
Step1.
Free download Wondershare DVD Converter, which can rip DVD and convert DVD to HD H.264 video. Install and run it with the overall interface like this.
Step2: Click "Load DVD" to import the DVD files, select output format you like, as well as the other settings to customize the output file size and quality.
Step 3: Edit the Video (Optional)
If you want to customize the video, this DVD to HD H.264 Converter offers a powerful video editing function, including cropping video, setting the video effects, trimming movie, even customizing personal watermark to meet your personalized needs.
Step 4: After finishing the presettings, back to the main window, click "Start" to convert DVD to HD H.264 legally, and the format conversion will progress in tune.
Now you see this simple yet one-stop solution on how to convert dvd to hd h.264 movie and play on iPod, iPad, iPhone, Apple TV, Zune, Xbox, PSP, PS3, Blackberry, and Android smartphones etc. at free.
And, If you want to know more about dvd converter and ripper, you will need dvd to ipod and free dvd ripper.Just have a try now.
on Jul 20, 2010 | Cell Phones
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
I want to know if you have to turn on the HD conponents cause i tried to use my xbox360 and thier is nothing on the screen. i already check the xbox360 wires and they are fine.
If you are using a high def tv and u want to play with hi def graphics, u must put the switch on the xbox av/component leads to HDTV, otherwise,standard def will be used. Check the tv input by using a dvd player or another input source to confirm it works. Good Luck.
Nov 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Connecting Projector to High Def Source (e.g. PS3 HDMI)
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
Feb 06, 2008 | HP Digital Projector xb31 Multimedia...
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
RCA D52130 52" Rear Projection Television Logo
461 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
