Worldwide 1994 Ford F150 Pickup 4.9L Alternator - 130 Amps Logo
Will Webb Posted on Oct 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seat belt light flashing 1994 ford f150
Seatbelt light and chime flashing
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Oct 08, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2134224
Points
13357
Check for a bad buckle switch jump it with a paper clip to test it
  • Thomas Glenn
    Thomas Glenn Nov 23, 2013
    tried jumping it did not do any good
2answers
2004 fx4 f 150 just got through disabling door ajar and seatbelt chime now odometer don't work and the radio stays on with the key out of the ignition
There is another legitimate and easy way to disable seat belt chime. Radio is supposed to stay on til door opens. That is correct
Pontiac grand prix 2008 seatbelt chime
fastening seat belts is not always the answer as some sensors need weight to cancel the light after the seatbelt is fastened. best have it checked out by an auto electrician as the seats may have been changed and the wiring not properly connected.
2answers
Is there a passcode or sequence to disable the
As far as I know that seat belt warning chime and light is there for your safety and protection, it should not be bypassed in any way.
There is no by pass seqwuence or code to eliminate this safety device.
Buckle up, its the law.
1994 ford tempo- automatic seatbelt is broken
under the seat there should be a plug for the sensor when you sit down it actuates the seat belt check that it is plugged in or that someone has not cut it to quiet the alarm chime if so reattach it
Drivers side seatbelt connected When truck is
sensor in the seat belt bukle needs to be replaced
Seatbelt chime and light go off even when belts plugged in.
You mean when the belts are not fastened right?
In the owner's manual it talks about how to disable the seatbelt warning by fastening then unfastening the belt in an exact pattern at an extact time.
I do not know if that will help but it may be a key to finding a solution.
7helpful
2answers
Seatbelt lock reset on f-150 pick up
rear seat belts lock if you pull them out all the way and put them ALR mode. Automatic Locking Restraint. It will ratchet as the belt is rewound. This is for holding a child seat in place.
Is this your issue?
1helpful
Audible seatbelt warning keeps on sounding on my 2005 f150 ford truck
From the F-150 Forums, since I just bought one and this worked!
This is straight from my 2009 f150 owners guide
Preperation
1. the parking brake is set
2. truck in park
3. ignition switch is in off position
4. both seat belts are unbuckled
Disable Belt-Minder
1. turn the ignition switch to the on position, DO NOT START THE ENGINE.
2. wait until the safety belt warning light turns off. (approximately 1 minute).
* step 3 must be completed within 50 secs after the safety belt warning light turns off.
3. buckle then unbuckle the seat belt nine times, ending in the seat belt unbuckled.
* after step 3 the restraint warning light, (airbag light) will turn on for three (3) seconds.
4. within approximately seven (7) seconds of the light turning off, buckle then unbuckle the safety belt.
* the restraint system warning light will flash four, (4) times per second for 3 seconds for confirmation
you can do this for the passenger side also!!!
*NOTE
in step 3. after three times buckling and unbuckling the restraint warning light lit up in my truck. SO I WENT TO THE NEXT STEP, (STEP 4). waited 3 seconds and i buckled and unbuckled.
in the buckle /unbuckle procedure do it some what slowly and watch for the light. it may not take 9 times.
__________________
3answers
Is there a fuse to pull to stop the seatbelt chime?
Pulling the fuse is not an option.Check your owners manual for instructions on how to shut it off..
Top Worldwide Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
