Question about Microsoft Windows XP Home Edition
Windows XP installation
I have an older Gateway that has been updated and has Windows ME installed, I want to install Windows XP home version but am not sure how to proceed. Should I remove the ME before installing or can it be installed overriding the ME installation?
  • 59 Answers
Make sure you back up any important files on that gateway machine before you install Windows XP Home because you may lose some during installation. You definitely will lose files if you chose to format the hard drive during your installation of XP which is recommended. After you backup, everything should be a breeze.
Posted on Dec 30, 2008
Microsoft Feeds Synchronization error keeps on popping up.
Sounds like your IE is corrupt, uninstall it from Add/Remove programs, this will revert to an older version, visit Windows Updates to re-install.
Mar 21, 2013 | Microsoft Windows XP Home Edition
Can not load older software on new pc with windows 7
The software Broderbund 3D Home Architect Deluxe 5.0 might works with the earlier version of Windows and does not work with the latest version. Check out the system requirement for the software and its says its for windows 98, 2000 & Xp hence the updated drivers for the suite are not released hence it would not be able to install it on New windows version.
Jan 07, 2011 | Broderbund 3D Home Architect Deluxe 5.0...
I can' get my Guide to good cooking to work on my new computer. I now have a HP windows 7 Home Premium. The cd is apparently for Windows 98, 2000, ME or XP. Do I need to get an updated version?
Either that or run 7 in XP mode. Here are some links to help you.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Hope this helps you.
Nov 26, 2010 | The Learning Company Williams-Sonoma Guide...
Xp installation problem
the system doesn't accepts the lower version of windows if you are having the latest version than xp. for thi you must format the two OS softwares and first install lower version i.e., xp and then by dual booting you can also install vista or windows 7. then you can use both versions..
May 29, 2010 | Gateway T-6330U Notebook
Is it possible to replace Windows Vista Home Edition with Windows XP on my Gateway M-6755?
Hello
Thank you for using
FixYa for your problem
I have checked on the Gateway website for the drivers for the model with XP and it does have them there so I believe the down grade should work
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Gateway M-6755 Notebook
Trying to download avg 8.5 free edition
You cant put 2k service packs on XP, try xp's sp3, it may solve the problem
May 20, 2009 | Microsoft Windows XP Home Edition for PC
Update could not be installed
Click here to download the dialafix tool, once installed choose to Flush Software Distribution Folder. Then Click go to repair the windows update files, that will remove the update & let you install any other updates available. Which version on Powerpoint do you have Office XP, 2003 or 2007?
Dec 25, 2008 | Microsoft Windows XP Home Edition
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
Oct 26, 2008 | Computers & Internet
HP PSC 1610v All-in-One Printer
Contact the home page of the printer and ask "what's up?"
Sep 15, 2008 | HP PSC 1610v All-in-One Printer
Not able to use as a Webcam
To use the Camcorder as a Web camera, the
following conditions must be met.
≥Windows XP SP1 or later is needed.
≥To upgrade Windows XP to SP1 or later, click
[Start] >> [All Programs] >> [Windows Update].
(Requires Internet connection.)
≥To upgrade Windows 2000 Professional to SP4,
click [Start] >> [All Programs] >>
[Windows Update]. (Requires Internet
connection.)
≥You have direct dial-up connection capability to
the Internet (minimum requirement). Also, you
and the other person(s) are on the same
Network (LAN).
≥Install Windows Messenger (Windows XP). If
you have a version older than 5.0, download the
latest version (5.0 or later) from the Microsoft
Home Page.
http://www.microsoft.com/
(For download and installation instructions,
please refer to Help on the Home Page.)
≥If the installed version is not the latest, update it
by performing the Windows update.
≥If you are connected to the Internet through a
firewall or a router, proper communication will
not be possible.
Only compatible with Windows Messenger and MSN mesenger
Hope this helps--pls dnt 4get to rate
Apr 13, 2007 | Panasonic PV-GS150 Mini DV Digital...
Microsoft Windows XP Home Edition Logo
175 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
