Need Remote codes for Toshiba ct-9953 - Televison & Video
I need universal remote code for toshiba CT-877
Universal remote setup codes for Toshiba Brand TVs are > 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Dec 23, 2012 | Toshiba CT-877 Remote Control
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
Codes for toshiba universal remote number ct-90302
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE. may have the code for you.
Mar 26, 2010 | Toshiba CT-90157 Remote Control
Our projection TV is showing double, like the words are duplicating red and blue outlines as well as the picture. It used to be that it would do it once in a while and a little bump to the TV would set it...
Not knowing the model, I would say that you have aconvergence problem. On most newer sets this can be corrected with the remote. Go to menu,then advance settings, then red or blue convergence
Sep 06, 2009 | Toshiba Televison & Video
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
561 people viewed this question
Top Televison & Video Experts
