Question about Whirlpool Duet GHW9150P Front Load Washer
Beeps 3 times when Power button is pressed
Our washer is just over a year old. My husband was doing a load of laundry and had no problems. The next time he tried to use it (very shortly after) and pressed the power button, it lights up, beeps three times, and then does nothing - no lights, no error codes, no nothing. Any ideas?
  • 530 Answers
Hi im josh in cebu phils. the problem is your washer is on a short circuit. try to check the wires if it has no cut.or loosen. good luck.
Posted on Feb 21, 2009
  • Joseph Baculan
    Joseph Baculan Feb 21, 2009
    hi im josh in cebu phils. the problem is your washer is on a short circuit. try to check the wires if it has no cut.or loosen. good luck.
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Kenmore Elite Oasis Washer 110.2709
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
387 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
