Question about Mitsubishi WS-65819 TV
The tv does power up at all, we need a new micro-processor board
I am told mitsubishi does not make a replacement part for the micro-processor board. This part is the brains of the TV that is very uncommon to not work at all. Is there anywhere I can pick up this board.
  • 231 Answers
There are 23 Parts available from =>
http://www.partstore.com/Model/Mitsubishi/Mitsubishi/WS65819.aspx?ModelAliasNumber=WS-65819
Maybe they have the part you are looking for.
This website for Mitsubishi has only 4 parts for the model =>
http://www.mitsuparts.com/
Posted on Dec 30, 2008
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Hey,, told we need a new power board.. can i do this and an idea of cost??? thanks, Woody.. mitsubishi wd 65734
Hello.
Part number 934c261001. Price $60-$180.
You can't buy Mitsubishi parts from vendors, only direct from Mitsubishi or sources like e-bay.
I can't answer if you can do this by yourself. I don't know how good you are with tools and ability not to break anything while replacing PCB board inside the TV.
In case if you will do it by yourself - please don't forget to unplug TV from wall outlet before start taking it apart. Everything should be accessible from the back of the TV, don't try to remove screen.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
I have a Mitsubishi WD-52525 television, purchased in Jan 2004, and have had various issues with the set since purchased. When the set was first purchased, it took three different deliveries to get a set...
Buy a new set - not a Mitsubishi DLP. I've repaired 3 sets at the board level.
Many, many bad capacitors on four boards, 12 hours to repair.
If a tech replaces one board, he is only fixing one of 4 bad boards and the set will soon fail again.
Apr 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Blinking green led light after power outage will not reset set is approx. 6 years old model mitsubishi w55511
had same problem with my tv.Technician told me to remoe front cover and unplug the 2 plugins going to the buttons then try the mistubishi remote to turn tv on.Did this and worked fine with remote.
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi TV WS-55511 Turns Off after Turning On
My mitsubishi big screen tv turns off in few seconds what should I do and I just got tv today please someone help
Oct 28, 2007 | Televison & Video
Mitsubishi vs-50703
NO POWER===Check all fuse devices on PS PCB. Shorted convergence IC's will cause that== change IC's.See what you have-let me know what you find.
Oct 01, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Mitsubishi WS-65819 TV Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
