Motherboards
Problem for ASUS Motherboards
Generic problem for all ASUS Motherboards
I need to install drivers on an old HDD for...
By gordonal123 on Dec 30, 2008
I have a HDD that crashed that was in my custom rig. I am swapping in a HDD out of a Gateway PC. They both have Windows XP Home edition on them with SP3 updates. The problem is that the Windows XP version on the Gateway HDD does not have any of the drivers to recognize the Asus K8V motherboard. I can only boot up windows in safe mode and since it cant find the drivers for the ethernet controller on the K8V it cant access the internet. Since it cant access the internet it cant find ANY of the drivers it needs to work properly with my K8V. I have relocated into the Gateway and I am looking for a zip driver file for the Asus K8V so I can download it. I plan to then swap it back into the Asus K8V mobo computer and load the drivers in safe mode and then restart. The new drivers should then recognize the K8V mobo and allow me to update the drivers online. I need to know where I can find 32 bit drivers for Windows XP HE for an Asus K8V? I need to know if this proceedure is the right thing to do? I need any suggestions at all for continuing this fix? Thanks.
Best Solution
posted on Dec 30, 2008
Helpful)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1942 votes
Hi gordonal123, installing drivers through safe mode is not recommended. If you want windows to function correctly than do a fresh install of windows. Over writing the Gateway hdd will cause you more grief. Windows registry will go nuts.
Link to download the Asus K8V drivers.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Here is what you need to do. Boot to your windows CD while using the Gateway system & hdd. Create a new partition within the free space of the Gateway hdd. (Follow windows onscreen instructions to create a new partition within the free space of hdd). (This will maintain the current windows function).
Restart windows when finished. Windows will create a second partition on the Gateway drive. Go to the Asus link above & download all the drivers for the K8V MB, onto the second partition of the Gateway hdd. Once downloaded & uncompressed into their own folders you can than boot to the windows CD & format the primary partition & install windows fresh onto the formatted partition. When finished you can install the K8V driver still located on the secondary partition. Copy & past these driver folders to your primary partition. Than use windows disk management software to erase / delete the secondary partition. (diskmgmt.msc).
When finished you'll have all the drivers for the K8V MB, no need to buy a PCI LAN card & more importantly a fully functioning windows with-out issues.
Good luck gordonal123!
Take your time.
Mike
Was this helpful?
Yes
No
Solution #2
posted on Dec 03, 2009
Not Rated)
amitdotin
Rank: Apprentice  Computer Components  Expert
Rating: 0%, 0 votes
I have 845 chipset motherboard onboard LAN is available. But that LAN Card Driver does not installed & also don't saw in the Device Manager.
So plz help me
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
installed MSI G31TM-P21 motherboard VGA will not work
Answer
I have a zebronics mother board with intel 845 chip. Now whem i power on that it give long beep and... (More)
Answer
L4S5MG/651+ P4 mother board, no display on power on two beeps, short and long,Phenoix Bios.. Tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
