Question about Twinhead SlimNote N12PI Notebook PC
Possible hard drive failure on SLIMNOTE N12PI
When booting up my notebook I get the following message
For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot Device and press a key
Checking the web for the PXE codes it seems to indicate a hard drive failure.
Is it true? If I have to replace the hard drive can I go from 80 gb to 160gb in the same space? Any recommendations as a good hard drive vendor?
I tried holding down the power and f4 keys to try and recover but it didnt work..
Help
  • jmdezso Dec 30, 2008
    I guess the next question is how to get to the bios? I get the PXE messages as soon as I power up
  • 39 Answers
PXE (Preboot eXecution Environment) means that
your network booting feature is turn on in your BIOS.
You supposed not to see it even if it's turn on, except
you don't have any booting device attached to your notebook (harddrive, diskette, ufd, cd/dvd-rom, others with valid operating system).
That means your harddrive have a problem. If your notebook is still in warranty period, sent to the vendor or place where you purchased it.
If not, (recommended only for experienced people) try to re-attached the harddrive connectors by opening the notebook first.
(at this time your warranty is void, and you will take any risks incurred).
Replacement should be with a 2.5" dimension harddrive for notebook (SATA or not depend on the notebook) and as far as i know, you can go for 80GB-160GB.
Recovery is useless if you are having hardware failure on your harddrive.
Posted on Dec 30, 2008
  • 59 Answers
I don't think its a hard drive failure thats causing that message, basically PXE means your computer is trying to boot from a network/server. All you have to do is go into your BIOS setup right after your computer boots. Then make sure your BIOS is set to boot from your hard drive and not anything else (floppy, network etc.). And if possible disable any PXE settings.
  • stejeda777
    stejeda777 Dec 30, 2008
    it depends on your computer, basically all you do is tap the f8 key or del key to enter your BIOS setup, you have to do this RIGHT after you hit the computer's power switch. Also take a look at the boot setting in your BIOS setup to see if your hard drive is showing up, if its not then for sure it has failed. At that point if you have important files only a data recovery agency would be the only ones able to recover your files, expect to pay thousands. also make sure if you replace your hard drive that you won't be voiding your warranty if it hasn't expired yet. If it hasn't go nuts,
  • 81 Answers
SOURCE: windows dont come up.
I had this happen to me before with an IBM laptop. I bought a new hard drive, reinstalled a fresh OS, and had no more problems after that. I also went right to ibm website and did all the updates, as well as all the microsoft updates. So my same problem as your ended up being a bad hard drive. maybe check into that?.
Posted on May 30, 2008
Benimur
  • 6966 Answers
SOURCE: My Toshiba Satellite P25 will
Hi and welcome to FixYa,
Initially, I am tempted to think that the CMOS/BIOS could not detect the internal hard disk and therefore is booting from the LAN. Pls reboot and enter CMOS/BIOS setup. Thereafter determine if the computer could detect the hard disk either auto or manually.
If the above solution has merit, pls click on my "Ask Me" to explore additional options, postback how things turned up or should you need additional information.
Good luck and Thank you for using FixYa.
Posted on Dec 03, 2008
  • 3278 Answers
SOURCE: wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Posted on Nov 26, 2009
  • 5603 Answers
SOURCE: I have a realtek RTL8139{x}/8130/810x PCI FAST
If you use ethernet, then your connection, possibly the cable, is not working.
IF you don't use the ethernet connection, and have no cable plugged in for ethernet, the warning is NORMAL.
Posted on Jan 11, 2010
parrotheadpc
  • 2600 Answers
SOURCE: Computer does not boot up
Sounds like the computer cannot find your hard drive and is looking for other means to boot the machine. It first is looking for a network hard drive, then it is looking at the DVD. When that fails it is asking you to check the computer for hardware errors. Check to make sure the hard drive is seated in it's compartment. The DV6000 has an adapter that fits on the end of its SATA drive and sometimes that adapter can wiggle loose from the contacts. Just take the hard drive out and then re-seat it to the connector. In most cases it is either a loose connection or the hard drive has suffered a failure.
Posted on May 19, 2010
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
May 19, 2010 | HP Pavilion dv6000z Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Will not boot (twinhead)
Have you tried booting in safe mode pressing F8 when starting up just after you power up, then a menu appears & you can try sytem restore from there or safe mode if you know what to get rid of on the system.
If not boot with a copy of windows in the drive & start again from fresh!
Hope this help's !
Sep 23, 2009 | Twinhead SlimNote N12PI Notebook PC
Upon booting I get this error. for realtek
PXE means Pre-Boot Execution Environment. You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error.
You have to replace the hard drive and reinstall the operating system?
Jul 09, 2009 | Toshiba Satellite P205-S747 PC Notebook
After the initial BIOS checkup, this error came up Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 PXE-E61: Media Test Failure, check cable PXE-MOF: Exiting PXE ROM what is this code and...
It looks like your machine is trying to use the network boot function, go into the bios and change the boot order so that your hard drive is the first boot device...
Feb 24, 2009 | HP Pavilion dv1000 Notebook
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
177 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
