Question about HP Office Equipment & Supplies
Can't set HP 2200 Inkjet to print online
Printer shows set to print offline.I WANT TO SET IT TO PRINT ONLINE.
The printer gets it's power from a power pack which was plugged into a power board which was successfully powering the computer and other peripherals.
By chance I discovered the outlet on the board was not powering the printer.By changing the plug from the printer's power pack to another power outlet the printer came online--- Problem rectified.
Thank you for being available if needed.
Billy B.
Posted on Dec 30, 2008
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
MY PRINTER IS OFFLINE AND I CAN NOT GET IT ONLINE
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online.
Aug 12, 2011 | HP Officejet 6500 Wireless All-in-One...
HP officejet 5610 does not print - Is it due to it showing offline? How to turn it ONLINE so that it may print?
Please follow below steps to make the printer Online
  1. Click Start ->Control Panel ->Printer and Faxes
  2. Right Click on the printer.
  3. Select "Use printer Online"
  4. Now your printer will be online for printing.
Please reply back for any queries.
Regards
Riztech
Jan 10, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is showing offline. I have unplugged and checked all connections, and have restarted the computer. The printer does not print a test page.
Try to right click your printer's icon. Check if the printer is set as the default printer or check if the printer is set to function online. It will not print if it was set to function offline.
Nov 22, 2010 | HP LaserJet P2015 Printer
Blinking green light< will not print. staus says it is offline
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Aug 02, 2010 | HP DeskJet 3650 InkJet Printer
My printer says its offline how do I reconnect? I've already done a complete power off and it's still offline.
hi
just folow the step
Step 1
· Step 2
· Step 3
· Step 2
· Step 3
· Step 4
Jul 07, 2010 | HP Deskjet 6940 InkJet Printer
HP laserJet printer 4100 is locked in idle or offline won't print
hi
· Step 1
· Step 2
· Step 3
· Step 2
· Step 3
· Step 4
Jul 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer will not print from computer
Check your printer setup to make sure the printer is online, and not set to offline. If the printer has offline checked, remove the check by clicking on the checkmark to re-set it to online. Are print jobs building up in the print que?
Nov 19, 2008 | HP Office Equipment & Supplies
HP photosmart C3180 stops printing
Posted by JACOB I understand that you are unable to print and when ever u try to print the jobs stuck in queue... When we right click on the icon if we see a option use printer online this shows that the printer is offline, if we see a option use printer offline in the list then this shows that the printer is online status. To resolve the issue we have to first clear the job in queue. Open the printer folder and then double click on the HP printer icon this will show the jobs in queue just right click on each job in queue and select cancel to clear the job in queue if there are still jobs in queue we have to performe the restart the print spooler steps by keeping the usb cable disconnected so that all the jobs are clear when the spooler is restarted. One the spooler is restarted just reconnect the usb cable and check if there are any jobs in queue. If there are no jobs in queue we can move ahead an set the print directly settings. Steps to set the print directly settings: Right click on the printer icon and select properties then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print to check with the issue. If the issue presists you can try to check with the port settings. Right click on the printer icon and select properties and then click on the ports tab and check if the virtual usb001 port is selected if not select it and click on apply and ok to save the settings if you don't see any usb port check if you have dot4 port in the port list select it and save the setting and try to print this should resolve the issue.. Once done try to print and if the issue presists you can try to refresh the usb ports. This will re-detect the usb drivers for printer and you will be able to print after restarting the computer.
Sep 16, 2007 | HP Photosmart C3180 All-In-One InkJet...
125 people viewed this question
Seeker5211
Seeker5211
