Question about Casio Exilim EX-Z500 Digital Camera
Zoom lens stuck in the out position
My zoom lenses appears to be stuck in the out position. I thought maybe it needed a charge and I did that and the camera will not turn on nor will the zoom go in or out automatically like it did. It looks to me like it is jammed so it clicks when you attempt to turn it on. I also tried removing the battery and installing it and that didn't do anything either. I'm afraid to take the camera apart so I haven't done anything else to it. Do you have any suggestions or can you recommend an authorized dealer that I can bring it to in order to be fixed? Thank you in advance for any help, Julianne
  • 374 Answers
If ur lens is stuck u are going to have to send it in to be repaired.
Posted on Jul 08, 2007
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
The zoom ring has limited use...maybe something stuck inside lens
If you are unable to maximize the zoom capabalities of your lens, the mechanical gears might have been jammed and or broken. Do not push it if it won't let you as you might break the lense. What you can do is to bring it to your local camera shop or service center to have it fixed.
Jun 09, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Zoom is stuck
There is a reasonable common fault where screws internally come loose and cause the zoom to jam - you will need to get the lens serviced.
May 30, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Hi there, I need accurate draving of EFs 17-85 or is parts list.Wish to order damaged part in side of the lens barel uder rubber ring for zoom to replace it.Is a litle metal electrical contactor with 5 or...
I bought a flex cable from ebay for my efs 17-85mm lens. Maybe you can try ebay and search for flex cable efs 17-85mm (to find similar suppliers) or search for the efs 17-85mm zoom contacts. The part that is broken sends the actual zoom position of the lens to the camera so that a Canon external electronic flash can correctly set its flash zoom position and the exif data is correct.
Mar 23, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoon function stuck at 17mm
foreign /broken piece /screw etcmight have struk in the guide and between guide-pins.
Mar 07, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Camera doesn't turn on and zoom screen got stuck because camera shut off!
MY CAMERA IS HAVING TROUBLE TURNING ON. THE OTHER DAY I TOOK A PICTURE AND IT SHUT OFF IN THE MIDDLE OF IT WITH THE ZOOM LENS OUT. NOW WHEN I PRESS POWER IT SAYS RETRY POWER ON OR IT WONT DO ANYTHING AT ALL. THE BATTERY IS CHARGED ALSO BUT NOW I CANT USE IT AT ALL
HELP!!!!
WHAT DO I DO!!!
STACY
Jul 21, 2008 | Casio Exilim EX-S500 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Frozen zoom lens
Sounds like there is a misalignment internally. This will probably need to be repaired at a shop.
Nov 02, 2007 | Nikon Telephoto 500mm f/8.0N Reflex Manual...
My cameras got an outty !!
Has it had a bump lately? Most times this is caused by the camera being kept in the glovebox or similar. The drive gears for the lens are very fine and delicate. They are not easy to pull apart either.
Jan 02, 2007 | Samsung Digimax 530 Digital Camera
Casio Exilim EX-Z500 Digital Camera Logo
114 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
