Question about Plumbing
Bathroom sink ''mixer tap'' leaking internaly.
Water is slowly oozing out from the inside the tap. NOT from spout. I'm not sure how to dismantle the tap to look for the problem.
Picture of tap can be found at
http://www.tekform.com.au/pdf/Sink%20Flyer.pdf
  • 1 more comment
  • Anonymous Mar 12, 2009
    Water is leaking at the (rotating) head joint of my Targa kitchen tap unit.
  • gerrydriscol Mar 12, 2009
    The (rotating) head joint of my Targa kitchen tap unit has become loose, and water is leaking at the joint, I need to know how to dismantle the unit.
  • Anonymous Mar 12, 2014
    removing spout from simplifit toronto mixer tap
    Novelist:
  • 148 Answers
If your valve is single handle there is usually a small
button type of cover for (sometimes rubber the size of a pencil erasure) that covers acces to a hex key screw that you have to remove to remove the handle
once you have removed the handle you will need a large adjustable wrench to turn a large nut that holds the cartridege tighten if still leaks remove and replace you can math the assembly at HD or Lowes
Posted on Dec 30, 2008
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
Dripping faucet
first step would be to change the rubber washer or o ring.
  1. buy a proprietary washer kit from any DIY store.
  2. Turn water off at isolating valve on teh pipe underneath the sink / bath or at the mains and or hot water tank as appropriate
  3. Remove the top of the faucet (often there is a plastic circle at the top that prises off to reveal a screw - mixer taps may have a grub screw on the side)
  4. Gently using a wrench to loosen the nut unscrew and remove the tap (faucet) barrell (middle bit)
  5. Remove nut that holds washer in place and remove it or, in the case of an O ring - prise it off with a pin or needle.
  6. Reassemble in reverse order - do not over-tighten.
If that doesn't stop the drip then the seat that the rubber washer / O ring seals against may be pitted or grooved. Either buy or hire a 'tap (faucet) seating tool.
  1. Turn off water before opening the faucet
  2. dismantle faucet as above
  3. Find which of the sleeve adapters that comes with the seating tool is teh right one to screw into the top of the faucet body
  4. select the grinding disc that is closest to the size of the seat and screw it onto the end of the seating tool
  5. Screw the tool into place in the top of the faucet body - just finger tight.
  6. Pressing down firmly with even pressure (but not too hard) on the top of the seating tool rotate the handle backwards and three or four complete rotations.
  7. reassemble the faucet but DO NOT close the faucet off
  8. slowly turn the water back on and allow it to flow hard for a few seconds to flush and debris out of the spout
  9. Slowly close the faucet and check for leaks.
  10. If necessary repeat re-seating process
Feb 27, 2011 | Home
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Sep 03, 2009 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
Kitchen sink leak
Hi
Where is it leaking from? is it a single spout/mixer tap?
Please verify, and i should be able to help you
Thanks
Steve :o)
Jul 17, 2009 | American Standard Home
Plumbing Logo
1,497 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
