Question about Maytag Performa PAV2200
Maytag performa the other night doing a load of laundry, noticed water would not stop running, went all over. Hose is already higher than water level,, wondering if water level sensor is the problem or if there is something else. And if this is the culprit how do you replace it.
    Habit-Forming:
  • 36 Answers
Does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Posted on Jan 01, 2009
Pressure switch?
sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Jun 13, 2017 | Maytag Washing Machines
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Door wont open laundry stuck in there now since Friday night...This product S-----!! NOT TO MENTION ALL THE MOLD ISSUES ALREADY...
you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
if the water comes out fairly rapidly you may need to replace the drain pump.
once the water has been removed you can open the door and remove the clothes.after everything is removed you need to remove both the hoses from the drain pump and look in it for any thing that will stop it from turning and or blocking the drain pump.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Oh Mr. Guru,please help!
for the second problem wher the water runs and never reaches level, check to make sure the drain hose is higher than the water level. if you allow the drain hose to come out of the machine and lay right on the floor with out first coming up above the height of the tub, the water will run out as fast as it comes in. hope this helps, let me know
Apr 21, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag Performa Washing Machine Issue
switch cold water off, remove hose. there is often a gauze filter, could be at either end. this could be blocked. alse peer into the valve where the hose screws on and see if any dirt build-up
Apr 29, 2007 | Maytag Performa PAV2200
Washing Machines Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
