Question about Philips 42PF9630A 42 in. Plasma Television
Help I am having the same problems as you with no picture and 7 blinking lights. Were you successful in fixing your tv with replacing all 3 y boards?
  • 2 more comments
  • donaldbc2 Jan 16, 2009
    Thank you for your help. If I try and fix my T.V. I will do just as you advised. There are so many great deals right now that I figure it is probably best to buy new and have a warranty. I'll be spending close to the same price.
  • Anonymous Jan 18, 2009
    7 blinks on red light
  • donaldbc2 Jan 20, 2009
    I will have to admit by contacting Philips through email they have responded helpfully. They are willing to replace my TV even though it is out of warranty. They said they will pickup my old TV and deliver a new one this week. If this truly happens I will be a fan of Philips for Life because they are standing behind there products. My suggestion is to go to Philips website and email the President and someone will from his Office will be in Contact.
    Good Luck
  • pacnt1 May 11, 2010
    Actually no, I replaced all three but still no picture, Im ordering the powerboard next, hopefully that will fix it.
    Scholar:
  • 73 Answers
I can't promise this is a fix for your tv, but I've had two so far with that same ailment. You need to replace the YSUS and BOTH buffers, if you want to do it one at a time to avoid any unnecessary costs, pull them and look them over carefully. If you see any burns on the bottom of the boards or if the hot glue around the heat sinks has gone brown, thats a telltale sign that the chip underneath is toast. Here's the next problem. Those buffers aint cheap....ebay's best price is about $150 each. Start with replacing the Ysus, then move on to the buffers. If you need help or advise in your dismantle, let me know and I'll send photos. Good Luck.
Posted on Jan 16, 2009
  • Axle80
    Axle80 Jan 20, 2009
    If you plan on doing that, let me suggest something to you. That panel is worth $$$ mucho dinero. Don't dump the TV, put it on ebay. Be sure to advertise that the panel isn't damaged. That should be an extra couple hundred bucks to put toward your new set! Also, if you didn't notice that the boards and even the panel are made by samsung and LG. A lot of folks are brand specific but don't know that what they are buying is all made by the same people just with different casings. If you do get another by a brand you recognize, but don't discriminate philips because of this experience.
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Jul 27, 2008 | Mitsubishi WS48511 48" Rear Projection...
Red Blinking Light/No Picture
7 blinks? Many have replaced caps on the SMPS board, with success: 2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 1 00μF 25v. Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Jul 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
7 red blinks
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Apr 28, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Panasonic th-42pz77u 42ed
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
Jan 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 42PF9630A 42 in. Plasma Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
