Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
I have a linksys befw11s4 router. how do i config it to an ipod
I have an ipod touch that shows the name of my wireless sigal but i cannot access the internet on it. i was told i need to have wpa. i was told it does. how do i config it?
  • 192 Answers
Contact apple
Posted on Jan 04, 2009
My broadbans session keeps expiring why does this keep happening
it is a config issue, or a weak signal.
start with chkg signal on device.
then chk device config
then chk router config.
Sep 28, 2014 | Linksys BEFW11S4 Wireless-B Broadband...
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a linksys befw11s4 router, i dont have a install disk, the router works, i just need to set up and secure my network, how do i do that?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or "1234" blank.
Then you can see configuration page of router.
If you are not able to access router then RESET it .You can RESET it with reset button it is in back side of router press it for 10 seconds then all settings goes to defaults then you can access it with above link.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | Linksys BEFW11S4 802.11b Wireless...
Changing IP address on computer with router linksy802.11b
access your router with ip.
open internet explorer if your defualt router ip is : type this in addres bar in IE. then neter username admin and password aslo admin
if not accepr blnk user name and passowrd is admin.
then go to ssytem then set ip and follow the procedure.
Oct 06, 2008 | Linksys BEFW11S4 802.11b Wireless...
You need to access the router setup page by typing on the address bar of a computer that is working with the router , then it will be asking you for a username and password , just leave the username blank and password is admin, then on the linksys page just go to status there you can see the firmware version....
Hope that helps..........
Sep 29, 2008 | Linksys BEFW11S4 802.11b Wireless...
Already tried it..
I can't tell if you tried turning off wireless, HARD WIRING your lap top to YOUR linksys. Did you.
Another way to see if you've done it right, it to turn off your Brother's linksys to see if you can still get onto the internet.
Also are there OTHER wireless routers in the neighborhood? It doesn't sound like you8're communicating with YOU router.
Mar 14, 2008 | Linksys BEFW11S4 802.11b Wireless...
I would first reset the router to the defaults - Hold in the reset button (a small pinhole on the back of the router) for about 10 seconds and the lights on the front will flash when it resets.
It should enable wireless with a network name called "linksys" and may just start working. If it doesn't you can download the user manual from for help setting it up.
HOpe this helps!
Dec 26, 2007 | Linksys Wireless Ap + 4 Port Router...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
