I am having problems with the above. I am not sure which connections to make and to what input source(s). I am referring to page 17 of the original manual and assumed that I would need to connect the cables ends to audio inputs as shown. I tried two cables, without any luck and also tried the sockets on the front of the amp, without any luck.
ANY advice would be REALLY appreciated.
Thanks,
Bob
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: I have the htr-5750 5.1 surround sound yamaha
You can you optical SPDIF cable - both xbox and your yamaha should support it. If you can't find cheap optical cable in your store, but it from ebay ($1-5 max.)
SOURCE: I need a replacement remote for the Yamaha
Your remote ID number is - RAV 250
Your remote part number is - WC552800
Cost - $32.95usd
And you can get the exact same one here http://www.yamaha.newremotecontrol.com/catalog_item.php?catnum=WC552800
Hope this helps
Regards,
Tony
SOURCE: some buttons on my remote for my yamaha htr 5750
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
