Question about Kenmore 24032\24036 Top Load Washer
Will agitate; but won't go into rinse or spin - even if place the
Dial directly on it. Thought it was the timer; but replacing the timer did not solve the problem. At this point, the only way to empty water is by hand. Has always been slow in moving through the cycles, but appears to only fill and agitate at this time. Putting dial on rinse will agitate; but nothing more. Placing it on spin does nothing. Won't go through cycle on its own. After agitating, just sits there.
  • jondailey123 Dec 30, 2008
    Works great. Thanks so much.
  • 242 Answers
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Posted on Dec 30, 2008
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Kenmore 24032\24036 Top Load Washer Logo
267 people viewed this question
Sal De
fordexpert
Robert Rankin
