Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I:\ is not accessible the file or dir.is corrupted and unreadable
Hi I have a maxtor personal storage 3200. 150 gig. and I cant access it I looked and it shows in my computer when i click on it it gives me that error.the file or directory is corrpted and unreadable.I ran chkdsk.and nothing. So I went to disk manager and the drive is there but it says it is [raw] not nfts.what to do next If I formatt it to nfts I will lose all data.please help.My maxtor 3200 is giving me the error message "file is corrupt and unreadable". I have thousands of valuable pics and video from the past ten year on it. I am so sad about this. Can anyone help? Where do I begin?
  • 13,433 Answers
Hi
find the drive letter
press start -> run -> type in cmd
-> type in the cmd window : chkdsk /F /X DriveLetter:
you can use filescavenger to recover files from the corrupt drive, formating will not erase your files.
http://www.quetek.com/prod02.htm
Posted on Dec 30, 2008
    Guru:
  • 731 Answers
Hi
Changing the Partition from FAT to NTFS will not delete the data.Its not a format.Could please paste the screen shot of the disk manager screen.
Thanks
Riz
  • Mohammed Rizwan
    Mohammed Rizwan Dec 30, 2008
    This problem may also occur, if the drive for Ext HDD is not recognized.Try Uninstalling the Device drivers in the Device manager.
    To access device manager
    1.Click start
    2.click Run, then type "devmgmt.msc" (without quotes)
    3.Hit OK.
    Thanks
    Riz
    Guru:
  • 449 Answers
If you removed the USB printer from the desktop and plugged the Maxtor external into that connector the Maxtor would work just fine.
Evidently the case front USB port(s) could provide enough power to run a thumbdrive but could not provide enough power to run the Maxtor external drive.
  • Jerry Parmanand Dec 30, 2008
    I also had this problem. So here is the solution. WARNING! DOING THIS WILL VOID YOUR WARRANTY! 1- Disconnect the HD from USB and power supply. 2- There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful) 3- Now you have a metal box in your hands. Unscrew and open it. 4- Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out. 5- Now slide out the hard drive and controller board out gently. 6- Unplug the controller board (power socket and IDE socket)from the Hard disk. 7- Look at the back you will see jumper settings. (Mine was set on Cable Select.) 8- Take the jumper out and plug it to Master ON position. now put it all back together. I have followed these steps, now my 3200 box works fine. I hope this helps. Good Luck do this if step 1 that i give you don't work.
Can't open downloaded files "old harddrive " after putting 2 GIGS of data in My Documents. can't access the individual files
Downloaded files often having its own format like WinRAR. You need to install requisite software, after than you will be able to open it. REMEMBER CASTING VOTE.
Sep 22, 2010 | Maxtor Personal Storage 3000LS (G01J040)...
Problem with my maxtor hard drive
all you have to do is reformat that drive
Jun 29, 2010 | Maxtor Hard Drive
I/O device error
Hmm? Your drive may be corrupted which makes it unuseable. I hate to admit your files may be lost at this point also. In order to reuse the unit, repartion and format the unit. I hope this helps.
Jul 14, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor 3200 200 gig not recognized
When your drive is in RAW format, the best thing you can do is try to recover the files and then get the hard drive replaced. I would recommend trying the trial version of this program: http://www.recovermyfiles.com
If that doesn't work, let me know, and I'll see if I can come up with another way to solve the problem
Feb 23, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Corrupted file message.can't open 3200
Had something like the same. The contents of an entire folder dissappeared.
I made a backup of all data I needed from the disk, then re-partitioned and re-formatted it. Now it seems to be ok again, but I lost my trust, so it will be a nice 500GB temporary folder for my PC.
from a command line, chkdsk was not able to run. Only at next boot. It started cycling with the same message all the time. Unfortunately I didn't copy the message
Jul 13, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Hi and thanks for writing back. I found that since the drive turned to a raw that windows will not read it.I don't know why it turned from ntfs to raw but it did. so I downloaded the O&O file recovery trial ver.to see if I could recover the pics. and movies.It took 5 hrs. to run and it recoverd everything.now I have to buy the software. but I know it is still all there.this software will even recover reformatted drives.Anybody that gets the same error mess. look to see if your file system has changed.If so it looks like recovery software is the only way to go.I have other good info on this and other maxtor hdd I will check back on post and write if you have sim.probs.
Jun 30, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 Some files not accessible when I switch computers
Unreliable drive. Remove and hit with a sledgehammer. Trust me. Do it now before u lose all your data. The 3200's are nothing but trouble. Did u know they use seagate hard drives?
Jan 01, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
External Hard drive Failure
Seems to me like your MFT of FAT is corrupt. You can go ahead and do a format on it by right clicking and going to format. You should then be able to copy your backed-up files back onto the drive.
Nov 12, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor access (pc and MAC)
Yes, formatting included erasing the drive and renewing the partition. If you want the drive legible on pc, but will be working in both environments, then you can do 1 of 2 things....
easiest, purchase MACDRIVE, it will allow a pc computer to see and use Mac items on the drive.
You could also transfer the content to another drive temporarily, format the drive in question to MS-DOS, then transfer all that content back over...using a MAC to do so.....
keep me posted..
Oct 28, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
194 people viewed this question
Top Maxtor Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Rick Arnold
swDemonDog
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
