Question about Apple iMac G4 Desktop
I book g4
Freezes at start up screen , mac os x, blue bar is full, stays on this screen forever
  • 86 Answers
Some of the start up files have been corrupted or are missing. Start up from the OSX system disc and them run Disc Utilities from the installer toolbar. Check the hard drive for errors. Repair any errors if they are found. If it's not possible for Disc First Aid to repair the hard drive you will need to replace the drive and re-install OSX.
Posted on Dec 30, 2008
I have a apple G4 book and when I start it up it will not go past the apple sigh and the screen stays blue?? Help Please
Hello and thank you for contacting Fixya Support, I am glad to assist.
I recommend you boot your Mac into Safe Mode, to see if you can remove a possible folder(s) which may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
I hope this helps. If you have more questions, please feel free to reply back to this post.
Regards,
Mactechtrainer
Sep 27, 2010 | Apple iBook G4 Mac Notebook
My mac air stays on grey screen how do i get it to boot !
Insert your Mac OS disc and start your laptop with the c key held down. It will launch the system on the disc instead of your computer. Once it reaches the desktop, you can choose "Disk Utiltiies" from the menu bar and run a disc repair on your hard drive to fix any damaged OS file... then restart without the OS disc.
Nov 19, 2009 | Apple iBook G4 Mac Notebook
During start up my ibook g4 freezes at the blue screen, which appears after the grey apple. why is that happening?
The blue screen marks the start of the login process. If the Mac freezes there, it usually indicates that some third-party System Preference is hanging the boot process. There are several ways to diagnose the problem. The simplest is to hold down the Shift key after hearing the boot chime. This will disable third-party System Preferences and should allow you to come up to the login screen. Then you can review the third-party preferences and go to the website of each of them to make sure you have the most up-to-date version that is compatible with your level of the Mac OS.
Nov 16, 2009 | Apple iBook G4 Mac Notebook
I was given an old emac g4. it worked ok, slow but worked. the dude that gave it to me had all his files in one directory, i moved some desktop items to make room for photoshop. now the box turns on ok,...
If you are not concerned about any of the files on the computer, I suggest just wiping it and reinstalling the OS from the original software discs - this will ensure there's absolutely no issues with the files on the computer. If you are concerned about saving data, this could get tricky - as it sounds like you've moved something in the user that the OS needs to boot. If that's the case, there's an "archive and install" option when you go to install, more info on that here. When performing this archive and install, be sure not to check-mark the box that says "preserve users and settings", as the user is corrupted - what it will do is stick the user in a folder on the drive called "previous systems", and you can access the data later from the new user created during the repair installation.
Nov 04, 2009 | Apple eMac G4 M9425LL/A Desktop
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
The circular timer startup screen NEVER STOPS! Powerbook G4
Hi
Safe Boot is a special way to start up in Mac OS X 10.2 or later when troubleshooting. Safe Mode is the state Mac OS X is in after a Safe Boot. To perform a Safe Boot, hold the SHIFT key as your Mac starts up.
Some features don't work in Safe Mode Safe Mode can be useful for troubleshooting. However, certain Mac OS X features do not work in Safe Mode. For example, you can't use DVD Player, capture video in iMovie, use audio input or output devices, or use an internal or external USB modem. The behavior of some devices such as an AirPort card may vary depending on computer and Mac OS X version.
Safe Mode in Mac OS X 10.5 or later also disables Quartz Extreme (hardware accelerated graphics). Applications that depend on Quartz Extreme will not open, and the Mac OS X menu bar will appear solid even if "Translucent Menu Bar" is enabled in Desktop & Screen Saver preferences.
Aug 03, 2009 | Apple PowerBook G4 Mac Notebook
Only have a blue screen on starting up iBOOK G4
Hello
It looks like you have a hardware related problem. have you tried anything since? I would guess that the hard drive is dead. Tell me if I'm wrong!
Mar 25, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Emac stalls on the OS X start-up
Start here...   Resolve startup issues and perform disk maintenance with Disk Utility and fsck  Mac OS X: How to start up in single-user or verbose mode  If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...   What is Safe Boot, Safe Mode?   Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack  Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Feb 01, 2009 | Apple eMac G4 Desktop
Apple iMac G4 Desktop Logo
131 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
