Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
I have a model ss3-e ingersol rand air compressor the muffler melted off (the filter got very dusty one day and I did not know it) and now the compressor will not go over 80psi. Do i need to have the compressor end rebuilt...its only a yr old
    New Friend:
Anything you need, can be found on amazon, click here and take a look: Amazon com ingersol rand air compressor parts. Wish you best of luck. John
Posted on Jan 10, 2015
    President:
  • Ingersoll Master
  • 1,388 Answers
The IRss3 pump has reed valves that will not seal properly if dirt or other debris settles on the surface of the seat. Indication of faulty reed valves or head gaskets is very hot discharge air, air discharged from intake and / or low pressure. Simple test is to check for suction at intake when the compressor reaches 80psi. Air should not be discharged from intake. Remove head and valve plate and inspect / replace parts as needed. Parts are available from WWW.grainger.com. Good Luck, happy holidays.
Posted on Dec 30, 2008
I have the same compressor (10yrs old), and now have the same symptoms and pressure limit issue. I will check and dismantle if necessary as described above. Great tips BTW !!! The compressor's parts sticker gives the following part numbers
  • filter element: 70243712
  • valve kit: 97338107
I have checked the Grainger website, and cannot find the specific filter or valve rebuild kit(s). Does Grainger have these listed under different part numbers, and if so ... anyone know what they are ?
Thanks!!!
Posted on Feb 13, 2009
I have the TS5, similar problem. You most likely need
the valve plate kit (valves not sold separately) to the
tune of $200, available from Ingersoll Rand. This is
a compressor pump with lower initial cost, but repairs
are expensive, since only whole kits are sold, when other
manufacturers sell the parts separately, very cheaply.
This pump turns at about twice the RPM as higher quality
pumps, and uses a cheap reed valve design. Just call IR and
you can order the parts from them. They have good
tech support. The upside is that this is an easy repair.
Posted on May 20, 2009
Hi Guys, I have a Ingersoll Rand Compressor 7/41. Machine runs perfect but I have noticed that the Exhaust & Manifold is glowing red hot. I know they heat up but this is excessive heat. Any idea what...
The muffler may have a blockage in it? Is the exhaust inabdormally quiet? That's the culprit! Someone has stuffed something in the exhaust pipe exiting the compressor housing body!
Jan 16, 2015 | Ingersoll Rand Air Tools & Compressors
Where can i get a tech manual for IR SS3??????????????????????????????????
They want you to register the product , possibly create a login and get a password, then using the link below you can login and using the serial or model number access documents for your equipment,
cheers, please let me know if this works for you
http://manualarchive.ingersollrandproducts.com/index.cfm?fuseaction=home.main
Aug 22, 2014 | Ingersoll Rand Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Ingersol rand model SS3-E runs but does not build any air pressure. Air just blows out the intake filter.
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Nov 26, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
Need manual for IR ss3-e compressor
I have worked on many IR compressors with the SS3 pump. A parts list can be faxed to you from grainger, use part #1WF72 for the pump only. Or try this address : http://www.capsaust.com.au/Uploads/Downloads/ss3-parts-breakdown.pdf
Order pump parts from grainger. The other parts can be replaced with generic grainger parts such as the pressure switch, check valve, capacitors etc. for the motor. If you are having a specific issue with your unit please detail the problem on your next post or email me. I will be glad to work thru the problem or modification. Good Luck!
Feb 20, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Air compressor trips breaker
check the ground wire most common mistake
Nov 18, 2008 | Air Tools & Compressors
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
1,957 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
